Thread: Calcium Hardness 500
    4-15-10
    I have 4 year old pool, 20000 gal, plaster bottom, fiberglass walls with SWG. Here are current numbers
    FC 7(solar cover has been on)
    PH 8 (added 1 qt muriatic acid)
    TA 100
    CH 500
    CYA 45
    Temp 83
    Water looks great, crystal clear
    I have read that with SWG and plaster I can keep higher CH but is 500 too high? Should I drain and refill a some?
    26,500 gallon, Hayward 200lb Sand Filter with Zeosand, 1HP Hayward Super pump, IG, vinyl liner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Calcium Hardness 500
    Welcome to TFP.
    It's high, but manageable as long as you keep the PH and TA in check... you should test your fill water- if it's high too there is no point in draining refilling if the fill water is high as well.
    Depending on where you live, Reverse Osmosis treatments are available to remove the CH if you desire.
    You should raise your CYA up to 60-70 - it will be easier on your SWG because you'll be able to turn down the % or run time. See Water Balance for SWG's in Pool School.
    Guest
    What a beautiful pool Welcome to the 'page!
    Thanks! I bought stabilizer today and will get the cya numbers up a bit.
    Next question: I have some type of widespread staining going on on the bottom. I have attached a couple of pictures. I used photo editing on one to make the stain stand out more in the photo. Its hard to tell from photos but this area is on the bottom in 3 feet of water. Any ideas of what kind of staining this is and if i should do anything about it?
    Thanks again
    The stains don't cause any harm, but they don't look very good and the longer you leave them there the harder it will be to remove them. If you do want to investigate what they are, try holding a vitamin C tablet against a stained area for 30 seconds and see what happens.
