Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: Please help with test results and some questions.
    Apr 2010
    Perry, Michigan
    81
    I was able to get everything running on my pool yesterday afternoon. I waited a few hours and did the testing. I tried to figure out the volume of my pool by using a pool volume calculator online. I don't know for sure how deep my pool is because we just purchased the house and the deep end is especially difficult to figure out. I believe it's 19' x 38' with a 4' shallow end and maybe a 9' deep end. That comes out to around 35,000 gallons (wow, that is a LOT of water!).
    I tried using the calculator on here to figure out how much chlorine to put in, but I don't know for sure that I got it right. From looking at the Pool School it looks like I'm supposed to shock the pool and keep shocking it fairly frequently.
    What is the ideal number of times a day to shock the pool?
    Do I test the water between each time I shock the pool?
    I put 2 gallon of the 12% bleach in my pool this morning about 8:15 and let the pump run about 3.5 hours. (I must say I am a bit surprised at how much the pool has cleared up after just 2 treatments... it doesn't look quite so swamp like anymore)
    I just tested the water after I turned the pump off and here are my results:
    pH 7.5
    FC 5
    CC 1
    TC 6
    TA 130
    CH 150
    What should I do from here?
    How long should I leave the pump running per day?
    Thanks in advance for helping me out with all of these questions.
    Apr 2010
    Perry, Michigan
    81
    Re: Please help with test results and some questions.
    Here are some pictures. The first two are of my pool 2 days ago and the next two are of my pool just a few minutes ago. I know I still have a long way to go, but I'm so astounded at what a difference a couple treatments of bleach makes!
    Definitely keep running that pump! The bleach looks like it is breaking up the mess.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    22,549
    Quote Originally Posted by trishalinn
    That's a lot of water alright. I calculated about 29,000 so it's probably somewhere between the two.
    You put your pool gallons in the cell for that then your current numbers in the "Now" column and what you want the numbers to be in the "target" column and that will give the amounts of each chemical to add.
    From looking at the Pool School it looks like I'm supposed to shock the pool and keep shocking it fairly frequently. What is the ideal number of times a day to shock the pool?
    There is no ideal number of times. You do it as often as you can as much as once an hour to begin with. The more often you do it the faster it kills the algae and the sooner you're done.
    Yes, that's how you know what to put in the now column of the pool calc so you'll know how much chlorine to add each time.
    pH 7.5
    FC 5
    CC 1
    TC 6
    TA 130
    CH 150
    Keep adding chlorine according to what the pool calc tells you to.
    What are you using to test with? If you don't have a good kit you really need one. You need to continue shocking until the water is clear, you have less than 1ppm FC loss overnight and you have .5 ppm CC's or less.
    While shocking it should run 24 hours a day. Once you're done you can adjust the run times to suit your needs.
    Apr 2010
    Perry, Michigan
    81
    I have the TF-100 test kit.
    Do I need to do the entire test kit between shocking? Or can I just do part of it?
    Thanks for all of the info! I'm going to go shock it again right now
    22,549
    Great! Just do the FC and CC tests while shocking. The pH will read high while at shock levels and there's no use repeating the rest of the test. Also, give us the CYA level if you've done that test.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Trish, Amazing progress. Keep up the good work!
    Apr 2010
    Perry, Michigan
    81
    Some more newbie questions with test results and pics
    Topics Merged by Moderator. Please keep all your questions in one thread, for consistency. Thanks!
    Hey hey!
    I'm back with more questions and test results.
    I shocked my pool 4 times yesterday (and once the night before). I'm seeing visible progress. The pool still doesn't have nice clear water, so I figured I'd need to shock it again this morning since I haven't shocked it since 9pm last night. I'm just a little stumped after my test results. So... here they are
    FC- 10
    CC- 10
    TC- 11
    I've tried doing the CYA test two times, and I don't know if I'm doing it wrong or what but that black dot never disappears.
    I'm going to go take pics and get them posted right away (if my kiddos let me!).
    Oh... and is everyone having wacky weather?! In Michigan 80's yesterday, 60's today, and tomorrow 40's
    11,969
    Your CYA will be zero unless you added it. Edit: I re-read the other posts. I'm sorry this was not explained more clearly. Sometimes CYA drops to zero over the winter, we aren't really sure why it happens in some pools and not in others. You'll need to purchase some - it's sold at Wal-mart in 3 lb containers. Use the Pool Calculator to see how many pounds you'll need. If they don't have it in stock, you can purchase it at the pool store. Look for Cyanuric Acid or Stabilizer on the label, make sure the % strength is at least 90%...)
    FC + CC = TC, so your CC can't be 10 if your TC is 11....
    Wacky here too, I was laying out by the pool yesterday
    Apr 2010
    Perry, Michigan
    81
    Here are a few more things I've noticed. The color of the pool seems better, but it's more cloudy today than yesterday. I could see the bottom of the pool yesterday, but not today. Yesterday there were all of these nasty slimy scummy floaty things on the top of the pool. They reappeared faster than I could clean them out with the net. This morning they are gone.... incredible disappearing floaty things?!
    Apr 2010
    Perry, Michigan
    81
    Quote Originally Posted by frustratedpoolmom
    Sorry I was typing too fast and with kids on my lap
    FC 10
    CC 1
    TC 11
    11,969
    Ok, I updated my post above with regard to CYA.
    If your CC is 1, you still need to shock. But I suggest this morning if you can, heading out to get some CYA so that you can protect the FC during the daytime, and then resume shocking. Eventually the CC will drop down to .5, but you still have a ways to go yet.
    Remember, brush, brush brush!!!
    POP - Pool Owner Patience... this will be important now, sometimes the home stretch is the hardest part
    Apr 2010
    Perry, Michigan
    81
    So, how do I know how much chlorine to put in if my FC is 10? Isn't that the shock level in the pool calculator? I won't be able to get out to Walmart until late this afternoon. But I'll make sure I'll do it ASAP.
    11,969
    You can just leave the FC alone for now.
    Apr 2010
    Perry, Michigan
    81
    What number should I shoot for with regard to the CYA?
    11,969
    Target 30 for now, just in case there is a small amount in there, that is too low to register.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    This could be a contender for the Slime to Sparklecontest.
    Apr 2010
    Perry, Michigan
    81
    Here is a picture of what used to be my black swamp as of yesterday evening. I'm glad I took a picture before we spent time scrubbing everything down again because the water turned green and murky again!
    It's COLD here today, but I'm going to get out there and test the water and report back in a little bit. I'm going to keep scrubbing away again today!
    11,969
    It maybe murky but the color is definitely bluer. Good job
  20. Back To Top    #20
    Apr 2010
    Perry, Michigan
    81
    Thanks, but this morning the water is greener than in the picture. Here are my test results:
    FC- 10
    CC - .5
    Do I keep shocking today when the FC drops below 10?
