Results 1 to 13 of 13
Thread: Fixing up the pool...pictures of my headache.
    Hello all, sorry for this long freaking post. I have been off and on the board for a while getting ideas and getting ready to do something with my pool.
    Long story short, I was going to remodel my pool last year but like so many other was laid off with the fun economy and all. Needless to say all plans immediately halted as the family went into conserve mode.Thankfully I now have a new and better job now so pool plans can continue.
    I have owned this house/pool for the past 6 years, pool was on it's last legs when I got it, things have not improved....yet.
    The pool was built in 1978, I have the original plans and specifications (even the building permit!!) from the previous owner.
    All equipment is original from 1978 except the pump.
    Here is what I have:
    22k IG gunite pool.
    16'x34' - 535 sqft
    1 main drain with 1.5" copper pipe.
    2 Skimmers, the kind that connect through the main drain. (I only have 1 suction line from the pool)
    Master-Supply Turbo Clean in floor cleaning system: 5 stations, 2 heads per station. (Each station has 1.5" pipe, this is my only return to the pool, can't bypass)
    52 sqft DE filter w/separation tank. Old Sta-Rite with 10,000 bolts around the edge (haha)
    2 HP Single speed pump.
    250k BTU Laars Teledyne heater. (has only been used 3 times in 30 years, never by me)
    Attached spa w/spillover (3.5' deep)
    Spa drain is 1.5" copper pipe
    Spa has 4 jets from a single 1.5" copper return
    Spa has a Master-Supply Air bar system with a 1 hp blower.
    Pool had a solar heating system installed sometime in the early 80's, panels broke at some point and were removed from the roof. 2" PVC supply and 1.5" PVC return lines remain in place and are capped off on the roof.
    I will post pictures of my existing system in the next post. For now this is what I have planned to do:
    1. New filter - already bought (craigslist) a used hayward 72 sqft de filter in good condition.
    2. New pump - have a spare (used) 2 hp single speed pump I bought off a friend a few years ago for $100, in good shape.
    3. SWG and Automation - thinking of the Aqua Logic Plus, two birds one stone
    4. Spa Blower - new or pick up used from craigslist
    5. Heater - keep and try to clean up for re-use
    6. Solar - Maybe wait for next year.
    7. In floor cleaner - new water valve and retro fit pop-up replacement heads. This item alone is like $700
    8. One of the skimmers doesn't work (pipe clogged?)
    9. Pool has a leak from a failed patch that I need to repair.
    10. Clean out as best I can the drains and returns, lines are filled with algae and gross stagnant water (filter and pump died 2 years ago)
    11. Air bar in spa is cracked - scratching my head on this one (see pics in next post)
    12. I will hit the pool and spa really good with a pressure washer, I was advised against acid washing.
    Let me know what you guys think.
    Re: Fixing up the pool...pictures of my headache.
    On with the pictures already!!
    OK DISCLAIMER
    My backyard is a mess, we are doing the pool at the same time as the landscaping in the backyard so we have "let it go" for now. Forgive the weeds/mess.
    Here is the pool, that bane of my existence since we moved into the house.
    From the deep end.
    Different angle.
    Steps and spa spillover. That white splotch on the bottom right is one of the sloppy plaster patches I need to fix.
    Deep end from inside.
    The spa, you can see the air bar in the seat area and on the floor with chunks missing and no doubt filled with debris and scooge. I have no idea what to do here.....
    Equipment pad - the Frankensteined white PVC is me trying to bypass the filter and slide valve when they fell apart just so I could circulate the water.
    Another angle, I so hate that filter, even with an air ratchet it still took foooorever.
    Blower and breaker box/timer.
    Water valve with the top removed, gears are stripped and it gets stuck sometimes. They sell a tune up kit with new gears and spider gasket, should be good to go then.
    That's what i have to work with, let me know what you think.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    WOW... pool itself doesnt look bad at all, but that filtration system is wayy before my time. I wasnt even a thought in 79 lol.
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    I see a lot of potential in the pool itself. This forum does amazing things for my desire to go bigger, ad a spa, etc. etc.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Butterfly's Avatar
    South Carolina
    10,045
    Yes, lots of potential. We will be following this transformation and hope that you continue to provide pics along the way.
    What is your location, city & state?
    You're done SLAMing when:
    I am in Vallejo, CA (SF Bay Area) Progress will be a little slow but I am really wanting to get this done so we can swim at least for part of the summer. One of my big motivations is starting to teach my son to swim (he is 3). Funny how kids can change priorities. Honestly if it wasn't for wanting to teach him to swim the pool would have sat empty for a few more years.
    Feb 2008
    Denton, TX
    5,061
    Great pictures and I love the empty bleach bottle in the deep end. Keep us posted on the progress and include photos. We enjoy seeing the projects spring to life.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,059
    You have a beautiful pool, probably was considered a top of the line and very expensive addition back in 1978. If I were you I would replace all the equipment, fill her up and enjoy. Add some landscaping and you will have a backyard Resort.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Thanks guys! I am working on it slowly, will keep you all updated. For now I am taking my time getting all of the new equipment, picking up used stuff can really save you big time.
    Bought a 72 Sq ft. DE Filter from a pool guy who removed it at the customer's request because the pool service was charging too much to maintain it! He cleaned it up for me and other than being a little sun bleached it's in perfect condition, flawless grids!! Best part is it only set me back $250.
    Rocklin, Ca
    467
    I have been seeing many people who sell all their pool equipment before their house gets foreclosed. I have been seeing lots of nice equipment on Craigslist.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Quote Originally Posted by cobra46
    Yep. I got a 406,000 btu raypak heater, 450 sq ft. sta-rite filter, two pumps, salt system, jandy one touch sub panel, actuators, valves, plumbing, and an automatic cleaner for $1,000. All the stuff was about 2 or 3 years old.
    15,000 gallon gunite pool, grey plaster with 8' raised spa
    Jandy PlusHP Pump 2 HP Dual Speed
    Sta-Rite 450 Sq. ft. Cartridge Filter
    Cleva-Chlor RP40HD
    Raypak 400k btu heater
    Jandy Aqualink RS-8 One Touch
    Savi Melody 12v LED lights
    Rocklin, Ca
    467
    n8scstm,
    great find.
    As I ponder and plan I have a couple of questions:
    Both my skimmers have no weir, I don't think they ever did as there is no place to attach them. Is this normal?
    Do I just use standard polyurethane caulking to replace the cracking stuff between the deck and the coping (where the weeds are growing up through)?
    Does anybody have any experience with the spa air bars that I have? (the strips embedded in the seat and floor of the spa)
