Results 1 to 10 of 10
Thread: Chlorine level in cold water?
    Sep 2007
    Toronto
    106
    I went to remove my winter cover yesterday. Water is a bit cloudy, I tried to shock the pool, but the FC is rising very slowly. The water temperature is 50, after adding about 5 gallons of chlorine(sodium hypochlorite 10.8 %), the FC is only about 0.5, the pool is about 8500 gallons, I have not started the pump or heater. Should I keep adding more chlorine or should I wait till I bring up the water temperature and shock again?
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Chlorine level in cold water?
    you need to circulate your water quickly...your low fc is most likely that the liquid chlorine has not mixed well with the water
    5 gallons of 10% at once in a 8500gal pool is enough to raise your FC to 60+ppm
    Yes, what dmanb2b said. You need to have some circulation going or the chlorine can all "pool" on the bottom and possibly damage the pool surface. If turning on the pump is difficult, brushing the pool will mix things enough to solve the imediate problem.
    Pacifica's Avatar
    Mar 2010
    San Diego, CA
    47
    Also, check your cyanuric acid level too and make sure that is in range as well.
    Sep 2007
    Toronto
    106
    Thanks for the quick reply. I just placed my cover pump into the shallow end and dropped the hose at the deep end to help to circulate. I'll post back in about half an hour. Funny thing is, despite having added so much chlorine, I don't get a very strong chlorine smell around the pool.
    OH TWINS
    Sep 2007
    Toronto
    106
    I just tested the water, FC is still at 0.5, I even raised the temperature of the sample to 75 F (by placing it in a microwave), FC is still at 0.5. Is it possible that I got a bad batch of liquid chlorine? Because even right from the bottle I could smell chlorine but not very strong, my wife confirmed that. The chlorine comes in a 5 Litre plastic bottle, it has a screw cap, you press down to open, but there isn't a paper or tin foil seal on the opening, is it possible that these are last year's left over stock and over time, some of the chlorine has dissipated? I have no other explanation.
    OH TWINS
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Quote Originally Posted by Ke
    I'd bet on it.
    There's a big box hardware store near me that sells pool stuff out in the garden area. (Can you guess who?) The pallet of Chlorine looks pretty weather-worn, so I've given it a pass.
    Sep 2007
    Toronto
    106
    Sorry everyone, I just tested the water again, the FC at the deep end is over 60 and only ahout 5 at the shallow end, so it has to do with circulation, my CYA is less than 20, now should I worry about too high chlorine, tomorrow will be a sunny day, I should just let daylight break down the chlorine. At least my pool gets a good shock.
    OH TWINS
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    60? Yikes - yes, definitely let the sun do it's work.
    Did you use the pool calculator first, do determine dosage? high FC levels can be corrosive, best not to make mistakes like that in the future.
    Sep 2007
    Toronto
    106
    Tonight the FC is down to about 20. I have the cover pump running non-stop. I will wait till the FC to fall below 10 before turning on the pool pump.
    OH TWINS
