Results 1 to 7 of 7
Thread: Pulsating returns
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    Pulsating returns
    When my pump is in low speed, one of the returns is kinda pulsating and making tiny bubbles at the surface. When is Hihg-speed mode its fine, but the floor returns start to pulsate.
    Its a new pool and will call the builder on Thursday to check it out.
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pulsating returns
    Welcome to TFP!!
    My quick analysis is that you have an issue with the pump lid. (on low, there's not enough suction to fully seal it which is corrected when high kicks in )
    Of course, there could be something else...
    Luv& Luk
    -Ted
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by waste
    Welcome to TFP!!
    Thanks, I checked it. Its seems to be sealed tight as ****.
    Pulsing is usually caused by air getting into the pump strainer basket relatively slowly. The lid of the strainer basket is the first place to look, but also check that the water level is high enough on the skimmer(s) that no air is being drawn down the vortex. If that is alright, you need to look for somewhere else that air might be getting into the plumbing between the skimmer(s)/main drain and the pump.
    Apr 2010
    Coral Gables, FL
    197
    Thanks Jason. I checked all that and nothing. I will contact the builder to have them look at it.
    Mar 2007
    4,160
    Of course, I overlooked that its a new pool and the PB should diagnose and correct the issue
    Please let us know what Mr. PB says
    Luv& Luk
    -Ted
    Apr 2010
    Coral Gables, FL
    197
    Well, they said it could be a few things:
    A clog somewhere in the pipes
    Chlorine being generated by the SWG (Yes, my chlorine in over the top now)
    Air in the system.
    Well it stopped yesterday after I reseated the the lid on the pump and open the cartridge valve and released water as it filled.
    No I am not sure which it was. But the PB is rated very high as their tech/warranty
    So I am not sure which it was. But the pulsating and the champagne bubbles on the surface are gone.
