Results 1 to 8 of 8
Thread: Is this a bleach stain on the liner?
    buddywiser's Avatar
    Morgantown, WV
    98
    I normally pour the bleach in over the jets, but in the past I've had other people pour it in for me when I'm away. This stain was here last year and I'm not really too worried about it as the liner is nearing 15 years old. This stain goes from the top to the bottom in the deep ind and there is a distinct outline from where it is not stained.
    I'm assuming that its bleach related but thought I'd throw it out here.
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Is this a bleach stain on the liner?
    I doubt it is from bleach. If anything, the liner would be lighter if bleach was damaging it. It could be that you have some metal that is being precipitated by the high concentration of chlorine when you pour the bleach in at that spot. Try a vitamin C tablet on the stain to see if it is metal.
    buddywiser's Avatar
    Morgantown, WV
    98
    John, I'll try this when I get a chance. All I can find are some Flinstone chewables right now
    Hayward Super Pump
    buddywiser's Avatar
    Morgantown, WV
    98
    Well, I never did get around to doing the Vitamin C test. I picked up a Jack's Magic ID kit to see if that would tell me anything. I put some of the Stain Solution #1 (Iron, Cobalt + Spot etching stuff) in a pantyhose and dropped it in the pool. It left a clean streak on the wall as it went down. That stuff must work pretty well. I see you can get it in 1 and 2 pound jars. How much would I need to treat 24K gallon pool?
    Are there other options/recommendations?
    Hayward Super Pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Read All about metal staining.
    There is a link to doing the AA treatment - in that article are the dosing instructions.
    Stain Solution #1 is the same as ascorbic acid.
    buddywiser's Avatar
    Morgantown, WV
    98
    Thanks, ordered some AA
    Hayward Super Pump
    buddywiser's Avatar
    Morgantown, WV
    98
    Another question...is there a preferred sequestering agent to use when doing the AA treatment?
    Edit...Nevermind, I see there's a post below discussing this
    Hayward Super Pump
