Results 1 to 11 of 11
Thread: Rinsing Cartridge Filter?
    smc's Avatar
    Oct 2009
    Tucson, Arizona
    53
    I must waste 10-15 gallons every time I spray my filter. I let the water run into my compost heap, but is there a better way that uses less water? I know they sell filter genie type ends for use in California, but I think I would still use the same amount of water to get the filter clean.
    (Somebody suggested to me that I throw the filter in the pool and let it soak for a few hours. )
    26k gallon IG plaster/shotcrete
    Pentair 1 HP Hydropump
    C-9419 catridge filter
    Kreepy Krauly Cruiser
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Rinsing Cartridge Filter?
    How often are you cleaning the filter? If you are cleaning it fairly often it is probably too small for your pool. I clean mine maybe twice a year.
    Mark
    I use one of those high pressure fittings for my garden hose. It's not "pressure-washer-strong", but good enough to make quick sweeps through the grids to clear the dirt and debris. At this point, I have it down to a science and can clean my filter in probably less than 5 gallons of water.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    smc's Avatar
    Oct 2009
    Tucson, Arizona
    53
    Frequency depends on how much dirt and debris gets blown into the pool. Sometimes once a month, sometimes every week, sometimes every two months. I think this is (mostly) the original setup from 1976. If I had a block wall I'm sure it wouldn't need so much cleaning, but I'd still have tiny leaves gettin' in there past the skimmer basket and the filter basket. I need to try filter socks and see how much I replace them...cheaper than a $95/year cartridge?
    I think I exaggerated the wasted H2O, but any way to save/reuse is great by me.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You do not have to replace your cartridge every year. They should last several years with proper care and cleaning. Instructions are here.
    For skimmer socks - I purchased cheap ladies knee high nylon stockings - 10 pairs for $2. It def helps keep tons of crud from going to the cart. You can hose those off quick or just toss them, up to you, depending on the amount of crud you get you should change them daily to every other day or so. During peak pollen time I rinse mine out daily. So much easier than having to clean the cart completely.
    From what I read, it seems that you have one filter cartridge that has 200sf of filter area for a 25-30K gallon pool. If this is true, sounds like you are under filtered. Our 20K gallon pool has 4 200sf cartridges. May be time to upgrade.
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
    200 sqft is commonly sold for a pool that size and it will work, but it does take more attention than if you have an oversize filter. We always recommend getting an oversized filter, so I would recommend a larger filter, but there is nothing "wrong" with a 200 sqft filter for a pool that size.
    smc's Avatar
    Oct 2009
    Tucson, Arizona
    53
    Now that I think about it, this cartridge is over 2 years old - time goes by fast these days. It still looks new, and the only reasons I threw the other one out were because the bands were gone and the previous owner told me it was past time to change it.
    Still learning. I've also been told that my pump is too small and it'll burn up. Still going and it seems to be doing its job, although it's a bit louder than I'd like. I've read most of the tutorials on here and they are excellent! The size of the pool may be off, but that is what I got from the calculator and the previous owner said that was right, and they don't build residential pools this big around here anymore!
    (And yes, I still have a pool service *booooo!* only because it's cheaper than buying BBB at the store now. And I don't want to put a hard-working American out of a job.)
    11,969
    We don't 'booo' folks who can afford a pool service. If u can swing it then by all means LOL
    Quote Originally Posted by frustratedpoolmom
    If we ever use a pool service, (not very likely) I would certainly test the water to make sure the service is doing it's job. It is very possible to have a pool look good and have the chemistry way off. JMHO
    I sit corrected
