Thread: Tool for stuck PVC valves?
    I have a number of the little red PVC valves throughout my pump setup to control the skimmer, main drain, intake for the vacuum, etc.etc.
    With the pump off, they're still a pain to move with bare hands. Upgrading to a wrench, I've managed to sheer the wings right off from one of them. Is there a tool specifically used to gain leverage on stuck PVC valves? As they are plastic, I'm hesitant to use anything heavy duty (again) but would like something dependable I can always count on.
    If only there were PVC valves with long handles like the jandy valves but not ridiculously expensive.
    Denis
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Tool for stuck PVC valves?
    These are better http://www.seagatefilters.com/images...0(400x400).jpg without being insanely high. They are Single Union Ball Valves.
    Aug 2007
    near the swamp
    806
    I use vice grips and channel locks. lol
    South Central NJ
    3,192
    That is the #1 reason why I hate ball valve. #2 is they will leak over some time. Pop the remaining piece of red handle off and use an adjustable wrench. The three way valves in the pictorial glossary also come in a 2 port version. Much more reliable and somewhat more costly, but unless you have additional changes, it's a 1 time fix. If they ever leak, you can replace the guts. No plumbing changes needed.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    Coastalish 'down easter'
    4,160
    It could be worse
    Y'all ever have the misfortune of seeing a Hayward 733 valve ?
    Luv& Luk
    -Ted
    Quote Originally Posted by waste
    It could be worse
    Heh. My last pool had one. It's the new owner's problem now
    Clearwater, Florida
