Results 1 to 13 of 13
Thread: I need Hayward Pro-Grid DE filter identification help
    sailman's Avatar
    Mar 2010
    Oklahoma City
    11
    I have a Hayward Pro-Grid DE filter that has the following possible model numbers listed on the info decal: DE2420, DE3620, DE4820, DE6020 and DE7220 but none of them are checked so i don't know which I have and therefore how much DER to use. Can anyone identify it from this pic or know what dimensions each one has?
    16K gallon chlorine, inground, plaster w/stone surround and waterfall, Hayward 3620 DE filter, 1 HP pump, separate 3/4 HP pump for waterfall
    22,553
    Re: I need Hayward Pro-Grid DE filter identification help
    Here you go. Measured from bottom to middle of air relief valve.
    DE2420 = 32" -- 3lb DE
    DE3620 = 34.1" -- 4.5lb DE Edited to correct model number. Thanks Paul
    DE4820 = 40.1" -- 6lb DE
    DE6020 = 46.1" -- 7.5lb DE
    DE7220 = 52" -- 9lb DE
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    When you were cleaning it, did you disassemble the grids to clean in between them? Sometimes caked-on stuff gets caught in there...
    sailman's Avatar
    Mar 2010
    Oklahoma City
    11
    I had planned on disassembly but the caked on stuff yielded to my hose stream and washed out the bottom.
    sailman's Avatar
    Mar 2010
    Oklahoma City
    11
    Thanks Bama Rambler!!!
    11,969
    Lucky you!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    3600 - eh? Now that it's properly clean and able to properly do it's job, you can keep it that way with my DE filter advice (which can be found here)
    Luv& Luk
    -Ted
    Jan 2009
    Cupertino, CA
    1,966
    DE6320 = 34.1" -- 4.5lb DE
    (picky, picky...)
    --paulr
    BBB "Intermediate Swimmer"
    22,553
    Good catch Paul. I called myself proof reading it to!
    Jul 2015
    San Antonio TX
    1
    Quote Originally Posted by Bama Rambler View Post
    Hello. I am trying to identify a Hayward also. Do you mean the bottom of the legs, or the bottom of the filter cylinder itself? Thank you.
    Apr 2015
    South Central PA
    298
    See page 4 of the link for a diagram:
    http://www.hayward-pool.com/pdf/manu...rid-DExx20.pdf
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    May 2017
    Daytona Beach
    1
    Are those measurements just vertical from bottom of filter to a point parallel with the air relief valve
    or are they up the side of the filter and across the top until it meets the air relief valve?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome Mitchell
    You may not get an answer here with this old thread, so we encourage you to start your own since these old ones aren't always followed very much. Normally I would move it for you first time, but it won't fit anywhere really. If you need the answer please do that and refer to this thread.
    Essential Links:
