Thread: Leak at light
    Leak at light
    If I have a leak at the light where would it most likely be and what is the best way to fix it?
    Thanks
    Roy
    This is a great board!
    Madison, MS 22,000 gal Salt Water. Intellichclor generator. Pentair sand filter. Waterfall.
    My name is Roy.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Leak at light
    Welcome to TFP.
    Most likely through the conduit for the wire. You can usually seal it with pool putty without draining the pool.
    Re: Leak at light
    Do you mean inside the conduit or around the outside of the conduit?
    My name is Roy.
    SW Indiana
    9,199
    Re: Leak at light
    Quote Originally Posted by Artist
    Inside.
