Thread: Nee some help
    Kentucky
    69
    Nee some help
    I am getting ready to open the pool.. I have filled it up to the correct level and am getting ready to take the cover off but did my water testing
    FC=7PPM
    CC=0
    TA=70
    CH=110
    CYA=20 I could still see the dot in the bottom even after it was full
    First I was wondering if I could go ahead and shock it with the winter cover still on and how long do I need to keep it at shock level? How much shock should I add?
    I am a little rusty as it's been a few months since I messed with the pool.... Thanks bunches....
    1) 16500 gallons
    2) 150 lb sand filter
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Nee some help
    Was the water circulating for several hours before you tested? If your FC is 7 I doubt you need to shock it at all.
    Edit: Also, did you allow the CYA test sample to come to room temp before conducting the test? Cold temps could affect the results.
    Kentucky
    69
    Re: Nee some help
    I turned the pump on last night and tested this morning so it was running all night... How is that possible to not need to shock or do anything to it after sitting all winter?
    I didnt really allow it to get to room temperature.. I mean it was sitting for about 10 minutes or so while I did all the other tests..
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    30,414
    Re: Nee some help
    How does your water look?
    Do you know how to use the pool calculator?
    Kentucky
    69
    Re: Nee some help
    I havent taken off the winter cover yet (still a little chilly to swim) so not really sure how the water looks... From what I can tell it looks clear...
    I used the calculator last year so I am sure I could figure it out again.
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    11,969
    Re: Nee some help
    Quote Originally Posted by momof3
    The last three openings since joining TFP I still had a FC residual and my water was clear and no CC's were present. My FC was holding overnight, so no reason to shock.
    We base the need to shock on specific things - like unusual FC demand, confirmed thru an overnight FC loss test; CCs that are greater than .5, green swampy water, etc. As long as you opened to clear water with a FC greater than your "min" for your CYA, your FC holds overnight and no CCs, there is no reason to shock.
    It's possible the CYA test is not accurate if the water was very cold. You can retest this or retest after you add say, enough to increase it by 10ppm, then retest after a week or so. Just make sure the water is room temp.
