Thread: Do I need to lower TA?
    Mar 2009
    Indianapolis, IN
    70
    Recently opened our pool and it looks great! Crystal clear water. I am wondering if I have to lower TA at this time. Not sure of the potential problems with a higher TA. Here are the numbers.
    TA 150
    PH 7.6
    TC 8.0
    FC 8.0
    CC 0
    CYA 35
    Thanks.
    18x36 ft
    19,000 gal IG vinyl
    Sand filter Tagelus 24"
    1HP Whisper Flo Pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Do I need to lower TA?
    I wouldn't worry about it unless you are having trouble holding pH in range. If you are having trouble with pH rise, just work on keeping the pH in the lower part of the range and your TA will drop over time.
    22,550
    You didn't list your CH level. If it's not high as well I wouldn't worry about the TA unless you're having issues with pH changing rapidly. Like John said if you keep adjusting your pH down with acid as needed your TA will come down a little each time.
    Mar 2009
    Indianapolis, IN
    70
    Well I just checked the CH and it is 400 which is pretty high. PH remains pretty stable with our pool. We have a vinyl liner pool. Do I need to do something to correct the high CH?
    Thanks again.
    18x36 ft
    19,000 gal IG vinyl
    22,550
    With CH and TA that high you have the possibility of scaling so I'd go ahead and work the TA down some. That'll help prevent possible scaling issues. Unless of course you want to drain some of your water to bring the CH down. That is if you don't have high CH fill water.
    Mar 2009
    Indianapolis, IN
    70
    I just checked our fill water and the CH is 300! We definitely have hard city water. I will work on lowering the TA. Thanks for all your help.
    18x36 ft
    19,000 gal IG vinyl
