Thread: Air in System
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    Air in System
    Not sure if I should start a new post or jump in this one
    If you are not sure, then please start a new topic! Thanks JasonLion
    I have the same situation as Maxomom, air bubbles in the pump basket. In the mornings after the pump has been off, the water is at the same level. I can't find any leak, so I am not sure where the air is getting in. Is it possible that this is a sign of the pump dying? There were 2-3 occassions in the past couple of days when for no apparent reason the pump basket suddenly would be only half full of water and after turning the pump on and off couple of times, the problem would somewhat correct itself.
    free form 40k gal, IG, plaster, Triton II 100C sand filter, Lite 2 heater
    1 1/2 HP Pentair Ultra Flow High Performance pump
    Caretaker in-floor cleaning system
    Re: Air in System
    This is not a sign of pump problems. Air in the pump basket means that air is getting into the suction side of the plumbing. That could be the water level being too low so the skimmer lets air in, or a loose or improperly sealed pump strainer basket lid that is letting air in, or a suction side plumbing leak.
    Toms River, NJ
    151
    Re: Air in System
    Just to add to Jason's suggestions, I had a bad seal on my pump basket (not in the lid) that was causing this last season - it was more easily traced by checking if water "spits" out from anywhere the moment you turn off your pump.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Air in System
    Let us not forget a skimmer weir that sticks intermittently
    Luv& Luk
    -Ted
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Air in System
    I opened my pool Saturday, and had been seeing some bubbles on and off. Turned out it was a loose union valve on the drain line. Year before last it was a bad O-ring on the pump basket drain plug. Any source of air will do it, as will a restriction of skimmer weir action.
    Feb 2008
    Denton, TX
    5,061
    Re: Air in System
    Quote Originally Posted by waste
    Yep, all it takes is a little twig to do it.
