Thread: Limestone coping cracked from freezing
    Jul 2007
    Birmingham Al
    Okay located in Alabama where cold weather is not normally a problem.
    This was an unusually cold winter and the limestone coping actually cracked/chipped evidently from holding water and freezing temperatures.
    Trying to find out if anyone seals their coping to prevent this.
    The stone company says they never seal.
    Any words of advice are appreciated.
    22,000 IG Gunite/Diamond Brite Pool
    Approximately 18 X 36 Free Form Pool
    Hayward Sand Filter
    2hp Hayward Pump
    Lana537's Avatar
    May 2009
    The Triangle, NC
    Re: Limestone coping cracked from freezing
    I don't have any advice, but I did want to say I feel your pain about the cracked and chipped limestone.
    We are renovating our pool, and we have just had limestone coping installed. I was never strong in geology, so I didn't know this about limestone!
    We are having the coping sealed by our pool builder, but I think that will be done on the top after the pavers are put in. Sealing is being done I thought for cosmetic reasons in order to prevent leaves and other organics from staining it. It wasn't treated before it was installed.
    After hearing of your troubles, I will now worry that at some time in the future, if some little bit of water creeps into, around, or under that coping, it will crack it in the winter. How sad! You have my sincere sympathy!
    25,000 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 1.5hp single-speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
