Results 1 to 7 of 7
Thread: I am interested in the BBB
    I am interested in the BBB. ARe you saying that you only have to use bleach, borax, and bicarb? Nothing Else? I currently use ez pool, and it keeps my pool clear, but it is very expensive.
    Madison, MS 22,000 gal Salt Water. Intellichclor generator. Pentair sand filter. Waterfall.
    My name is Roy.
    Re: I am interested in the BBB
    Welcome to TFP!
    No, the BBB method is named after those chemicals, but it uses a couple of others as well. BBB is really a set of principals about keeping things simple, understanding what your pool needs, testing frequently, and saving money whenever possible.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Hi Pearle...welcome to TFP.
    Read Pool School...button is on upper right of this page and it will be much clearer....depending on the size of your pool, once things are balanced, you will only be spending $15-$30 p/mo on BBB.
    As Jason stated, the key to BBB is knowing what's going on with your pool water, and for that we recommend a good drop based test kit. Either the TF100 at TFTestkits.net (Better value IMHO) or the Taylor K2006... will do, but without one of these your just guessing as to what your water needs.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You will have ZERO regrets by switching from EZpool to the BBB method - and money in your pocket to boot!
    Do it.. switch now.
    Did you switch yet?
    2003 Marquis Euphoria - 400gal
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,068
    BBB is the way to go You will not regret it
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Started from scratch with BBB, it's the only way to go!!!
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
