Results 1 to 8 of 8
Thread: Pump's dead - any advice?
    Pump is a AO Smith and less than 1 year old. Has worked great until this. I have tried bumping and knocking hoping the contacts were stuck. Can't reach the pump but seems unlikely that it's stuck on debris. I was reluctant to take off the back housing as its a tight fit against a wall and that will take hours to get at. Any suggestions?
    33K IG 1967 45' X 20' Roman 4-8 ft plaster/gunite. Triton Sand, 1.5 HP pump. Indoor with Screen Atrium top. Bought a Swamp with Nails Glass and Trash with An Algae Encrusted Astroturf Surround. On par and thankful to TFP since 4/2010. A good test kit is your friend! Using a K-2006, refills from TFTest kits.
    Mar 2009
    Charlotte, NC
    539
    Re: Pump's dead - any advice?
    I got a new AO Smith & it was loud! I called& let em here it, they sent a new one. Call em
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Feb 2008
    Denton, TX
    5,061
    What happens when you flip the switch? Does it make any noise or hum or anything like that?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    As it's a new motor, a possible cause is a stuck impeller. You could try removing the strainer basket and turning the impeller with a screwdriver (**be sure the power is off and won't turn back on while you're doing this!!!!**)
    Pics of the system are always welcome and often help us diagnose/ prescribe a fix
    Luv& Luk
    -Ted
    Thanks for all the suggestions. It is raining hard today so when it lets up I'll give the scrediver a try and report back.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    If it's less than a year old it should be under warranty. If you do end up fixing it yourself and it's not something you did wrong (like something jammed in the impeller) then I would definitely have them replace it under warranty.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2007
    near the swamp
    806
    if there's any rust or calcium deposits on it, it more than likely won't be covered
    It's Alive, It's Alive!!
    Thanks to all for the great advice and suggestions. The points were pretty pitted and scored. scrapped them down and did a bit of "gapping" and it fired right up. Reminded me of an old 4 cylinder car I had back in the days of points, rotors, distributors etc.
