Thread: Adding CYA and Pool Calc
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I use the iPhone app for the Pool Calc but I noticed the online is the same, but it only give measurements for Liquid Stabilizer. I am in a location that Leslies is my only choice and they only sell powered. Am I missing something in Pool Calc for dosage?
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Adding CYA and Pool Calc
    When I look at it the first line for that sections says "add _____ by weight or _____ by volume of Stabilizer "
    and the next line says "or _____ of liquid Stabilizer"
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by frustratedpoolmom
    Ah you are correct (for the online version) but that is not how the iPhone app is. It simply says"To raise CYA by xx in xx,xxx gallons, add xxx oz of liquid stabilizer. Thanks I will use the online version.
    Polaris 280 robot
    Pool Calc user
    11,969
    Oh, I see I misunderstood what you were asking.
    In the iPhone version of the Pool Calulator, go to the CYA tab and then press the setup button. That will take you to a screen where you can select which chemical you want to use to adjust your CYA level. You must have been to that page already, since the default is stabilizer, not liquid stabilizer.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Outstanding thank you very much. Right in front of my eyes but never saw that. I really do love the convenience of the app version by the way, so handy.
    Polaris 280 robot
    Pool Calc user
