Thread: First Time Opening Questions
    Jul 2009
    Long Island, NY
    267
    I have a couple of first time opeing questions that I need answered. My poolbuilder closed the pool for me last fall and I was not home to watch what he did. I understand that he put some antifreeze in the plumbing lines but I don't know what other types of chemicals he used to close the pool. My questions are:
    1. Is a DE filter typically backwashed as part of the winterization process? Should I open it up and do a full cleaning as described in the filter manual?
    2. What happens to the antifreeze put in the pipes? Do I filter to waste upon initial startup to get rid of it or is it safe to leave in?
    Thanks in advance for the help. We can't wait for our masonry work and landscaping to get done this spring and finally have a fully usable pool this year.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Re: First Time Opening Questions
    Yes, the DE filter should have been backwashed right before closing. Still, it is a good idea to open it up and do a complete cleaning at least once a year, and now is as good a time as any.
    The anti-freeze used in swimming pools is non-toxic. It is the same stuff they use to winterize the drinking water lines in an RV. Many people like to start the pump up with the main valve set to waste or backwash, just to keep as much of the anti-freeze out of the pool as you can, but it doesn't really matter if you do that or not.
    Jul 2009
    Long Island, NY
    267
    Thanks for the answers. I assumed that the antifreeze could be left in but wanted someone to verify it.
