Results 1 to 7 of 7
Thread: Replacing coping caulk
    I have an 11K in-ground gunite where the deck has settled a bit and there is now seperation in the caulk between the coping and deck. I would like to replace the caulk to improve the appearance. Should I just remove the caulk or the foam insulation with it and could someone recommend a type and brand of caulk.
    Pete in San Antonio
    11K IG Gunite/325 Serires Hayward cartridge
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I think you would use mastic to fill that gap.
    http://poolmastic.com/whatis.htm
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    30,403
    Pete,
    Polyurethane caulk is most commonly used in that gap. No need to replace the foam unless it is stuck pretty tight to the old caulk. The foam is cheap at a masonry supply dealer if you need it. Almost all good poly caulks will work. HD and Lowe's have good ones.....about 3-4 bucks per tube.
    It is a PITA to work with. Tape off both sides of the joint and then squeeze the caulk in barely over the finished level. Next, take a putty knife and CAREFULLY level it between the two taped-off sides. If you work slowly and carefully, you'll get a professional looking job.
    [quote=It is a PITA to work with.]
    Excuse my newbie status but what is "PITA"?
    Pete in San Antonio
    Mar 2007
    Morris, IL
    477
    Just to chime in, I have watched professional caulkers do their work before, and if it matters what it looks like at all, they do tape off each side of the joint. I would say though, professional caulkers don't use tubes of caulk, they generally seem to mix it and suck it into a caulk gun type thing, which more than likely is way cheaper than buying tubes. I would price things and get a bid and see what could be cheaper maybe. Not sure how big the gap is, but if it is say 1/2" wide, I would put the caulk in probably close to 1/2" deep, maybe 3/8" at the least (IMHO) I doubt it would go more than 5 feet per tube, probably more like 3... There are BIG tubes of caulk out there too, but you would need a big caulk gun.
    Good luck
    Steve
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2007
    Ontario
    211
    Pain in the ???-"PITA"
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    Mar 2007
    Morris, IL
    477
    Meh... I don't know, probably, but it doesn't really last forever, and if the ROI is worth it then I would definitely do it myself. That is the ticket though, could I use that money saved for something else? .......
    steve
