Results 1 to 11 of 11
Thread: weatherproof box for stereo
    Mar 2010
    Huntington, WV
    150
    I am wondering what people do to house their "inexpensive" stereos on their patio or deck? I basically have an old L/R stereo receiver and a pair of outdoor speakers and was wanting to use a box that I wouldnt have to bother getting in and out of all the time when I was going in for the night, etc. I was wanting some sort of a weatherproof box with front access/door to get to the controls and CD player/changer.
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    Mar 2009
    Charlotte, NC
    539
    Re: weatherproof box for stereo
    Stuff is so cheap may want to go get a boon box you can haul inside w 4 fingers
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Jun 2008
    Port Neches, Tx.
    144
    I cover ours with a towel when not in use.
    Noob Here!
    24' Above Ground
    Aquatrol SWG
    1 1/2 hp pump, sand filter
    Aug 2009
    North Central Texas
    1,358
    For less than $100 you can get an outdoor wireless speaker system; transmitter, two speakers and remote control. The transmitter hooks up to virtually any sound source you can imagine. I've had several different kinds of over many years and this is the very best I've ever had. Virtually no interference from any source. I, also, have the floating/waterproof ball and the headphones that I use every night when DH wants to go to sleep while I'm still watching TV. I wear the headphones if I'm working outside and don't want to crank up the sound on speakers as I get away from the house.
    The transmitters and speaker/headphone/floating ball receiver are all interchangeable. The headphone transmitter is also the base for charging the headphones. The speakers are battery operated or plug in. Ball, you have to put batteries in. I use rechargeable. We use that in the pool and spa.
    Check it out. Reviews are many and good. http://www.amazon.com/gp/product/B00...ef=oss_product
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Apr 2008
    Kentucky, USA
    2
    I had a older Sony receiver that I wanted to use with my outdoor speakers and bought one of these from Sam's Club:
    Suncast Serving Station Patio Cabinet
    A standard receiver, or any other standard sized components fit perfect. I put the receiver in the top shelf and used a hole saw to cut a small opening in the back to feed the speaker wire through. The extra storage on the bottom always ends up being used for extra towels, sunscreen, etc.
    The price has gone up considerably since I bought mine 3 years ago (about $80.00 shipped back then) but maybe you can find something similar.
    It really depends on where it's going as to how you want to build it. Really, the appropriately sized rubbermade container with exit holes in it would work well. You could get one big enough so you have front access to the cd tray, and then you can put the lid on it when you're done. If you have ross/tj maxx around, you'd be surprised at what you might find that would work.
    If you put it in any type of enclosure, though, make sure you leave the top off when you're running it, especially with older units, they'll burn themselves out in a hurry.
    I'm getting ready to get my stuff setup, and my plan of attack is actually going to be using marine setups they use in boats. You can get some cheap stereos that way with cd players built in, or to just run an ipod through.
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    Mar 2010
    Huntington, WV
    150
    I am thinking it might be easier (and cheaper) to just get an outdoor receiver? Does anyone have opinions for this one:
    http://www.amazon.com/gp/product/B00179DA46/
    24' AGP
    I like that idea. $66 is hard to beat, plus lots of options for speakers then since you're not paying for it.
    You can pick up a 12v adapter almost anywhere, but keep the power connections in mind too, they'll need to be water tight.
    You might be better off with a marine stereo though, the sound quality will likely be better (reviews aren't great on the sound quality.)
    Take a look over at home theater direct (htd.com) for speaker options. I have a ton of their stuff in my house, and it's awesome for the price.
    Richard
    Temecula, CA
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    What kind of system do you have inside? The reason I ask is bc I have an indoor receiver with 2 zones. Zone one is for inside/TV/DVD etc... Zone 2 is for outside. I have 2 hard wired speakers under the patio cover but you can also use wireless speakers out there. When I want outdoor music or TV sound I just turn on zone 2. The great thing is that if someone is inside watching TV using zone 1, I can be outside using zone 2. Just fyi.
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    esim13's Avatar
    Oct 2009
    320
    Also, If you're a DIYer you may be able to build a box out of plexiglass, hinge one of the sides. Turn it upside down over your equipment, hinged side to the front and voila!! You could leave the hinged side open while using and close it for the night.
    GEAUX TIGERS!
    Pics taken 2012
    Mar 2010
    Huntington, WV
    150
    I have 2 receivers, one that is hooked up to the TV, DVR, ps3, etc. It does have a/b speaker selector, but I would rather not use that one. I do have another receiver, just your basic 2-channel receiver with a/b speaker selector. This is the one I was going to use for the pool area. I bought some rock speakers on clearance to go with them.
    24' AGP
