Thread: Need help choosing a pump!
    Louisiana
    68
    I need to replace a my pump. I have an old doughboy 1.5hp and it's going bad.
    11,000 gallon above ground pool, salt, doughboy filter with 2sq ft. filter area and 225lbs. sand
    1.5" plumbing close to 30' long and I think it normaly runs at 11.5 psi.
    I was thinking that 1hp would be enough with the better pumps these days. Tell me your thoughts.
    These are the 3 pumps I am looking at. I want energy efficient and quietness. Trying to stay under $300
    I like the quick disconects on the speck but was told that parts would be hard to come by.
    http://www.poolcenter.com/pumps_speck_e91_poolstor.htm
    this one also has quick disconects. It says it's energy efficient
    http://www.poolcenter.com/pumps_hayw...x_poolstor.htm
    this one was suggested
    http://www.poolcenter.com/pumps_pacfab_dynamo.htm
    If there are any others you would suggest please tell why.
    11,000g, AG, aqua rite salt, Dough Boy 1.5hp, well water with some metal in it, and 2 beautifull oak trees that dump a ton of leaves into the pool.
    I use TF Test Kit
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Need help choosing a pump!
    honestly, I think the 3/4 hp would be enough for 11K gals...but hopefully some with more plumbing experience will chime in soon
    mas985's Avatar
    Pleasanton, CA
    11,741
    Yes, I agree, 3/4 Hp is enough. Also, I would stick with Hayward or Pentair with Pentair having a slight edge.
    Mark
    Louisiana
    68
    ok so pentair is the choice. I run my pump from 0100 to 0500 and from 1300 1700 each day and i set my SWG to 20% output So will I have to run the pentair for longer periods? Will i need to change the SWG output?
    Also for vacuuming I suppose it will take alot longer with only 3/4 HP vs. my 1.5 HP that I currently have?
    I use TF Test Kit
    mas985's Avatar
    Pleasanton, CA
    11,741
    A 1 1/2 HP pump has about 1.25x the flow rate and 2x the energy use of a 3/4 HP pump so you should only need to run the 3/4 HP pump about 25% longer than your current pump but you should end up saving about 40% in energy costs.
    The vacuum will slow down a bit but it should be proportional to the flow rate so given the run time is longer, it should do about the same job as it did before.
    Mark
    Louisiana
    68
    ok thanks mas985
    I use TF Test Kit
