Results 1 to 17 of 17
Thread: timer for pump or just manually plug/unplug?
    Mar 2010
    Huntington, WV
    150
    We just had our 24' AGP installed this week and we are in the process of filling it up. I was wondering about the pump. Should I just plug and unplug it when we want to use it? Should I find some sort of outdoor timer and use it that way? Or should I consider installing a switch and hardwiring it?
    What setup do you have?
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: timer for pump or just manually plug/unplug?
    I recommend you purchase a timer for use on pools - that way you can set the run time for whenever you like and you don't have to worry about forgetting to turn the pump on/off. On the other hand, if it's a 2 speed pump you can just let it run on low 24/7.
    22,553
    I don't recommend the plug/unplug method. That's really rough on the plug blades and receptacle. The arcing will burn them up. A timer is your best bet. It saves you having to remember to go out and turn it on and more importantly to turn it off.
    Mar 2010
    Huntington, WV
    150
    I thought that a timer was the best way, but wanted to make sure. I think I will install an underground line and mount a recp. box on a deck post and run all needed stuff from there.
    Thanks.
    24' AGP
    Dec 2009
    Central Massachusetts
    2,690
    Is this 120V I assume?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Feb 2008
    Denton, TX
    5,061
    Yep, get you a timer. A simple Intermatic mechanical timer should do the trick.
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    Are you guys all mounting your timers outside near the pool? If so are you just wiring your pump plug directly to them? Trying to figure out how to wire my AGP pump into a timer.
    Alan
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    I just use a simple 15A wall timer that's protected from the elements. Works great for mine, my pump doesn't pull more than 15A. You can also get 20A versions for heavier duty stuff. They are like $20 I think.
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    sammm's Avatar
    North Richland Hills, TX
    257
    A timer with a freeze-guard. (In case you're in part of the country where it does get cold)
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    11,969
    Good point Sammm.
    Jeff, you can put your location/general area in your user profile.
    Mar 2007
    Texas
    444
    I would suggest putting in a timer AND a switch wired ahead of the timer.
    27' Round AG, 17,200 gallons, sand filter
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by Poolidiot
    Since you have to have a dedicated circuit and line for the pump...you can have the electrician wire the timer right off of your circuit box in the basement or where ever that is...This way it is out of the way and you can control it from inside the house. It might just be easier...You could also look at a timer with multiple settings...run in early morning shut off in the later part of the day...then back on over night what ever you need.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by beartoothweb
    Please tell me where to get a 20a timer for $20?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Mar 2007
    Texas
    444
    Quote Originally Posted by cubbybeave08
    I was not recommending the switch ahead of the timer for turning it off and on, It is there as a disconnect for any time you have to work on the timer /circuit.
    Feb 2008
    Northwest Indiana
    902
    I don't think I was replying directly to your suggestion...I think I just hit quote instead of just reply. I was saying putting the timer in side might be a good idea...If I had it to do over again...I would do this...because on mornings like today It would have been nice to go down and reset the timer from the basement instead of having to reset it by walking outside when it was 41 degree's.
    Beave
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    In preparation for having my 16x32 AGP installed on May 10th (God willing) I had the electrician run a line from my breaker box(dedicated breaker) to the rear of my house. Had a Tork time switch wired before the dual plug. Think the timer was around 85.00 or so. Has metal set screws, not plastic.
    I personally installed a heavy duty relay (PCS UPB), so I can control it from inside the house. Relay is installed inside the house, so it's easy to access it.
