Results 1 to 11 of 11
Thread: Anyone know what kind of pump I have?
    kjdiver's Avatar
    Jan 2009
    Virginia
    69
    I am having trouble getting the pump to prime so I think I need to replace the lid gasket? I've only had the house for over a year and I think the pump is at least 10+ years. On the lid cover it say Wet Instrument and Environmental Tech. I can't find anything when I google for it. Here is a picture. Thanks!
    25k old school pool - new plaster and tile Dec 2017 -> Jandy FHPM1.5-2 -> Tagelus 60 -> CompuPool CPSC48 -> Raypak Heater -> RIP: Polaris 380 w/ booster pump - New Cleaner: S300i Mar 2018 -> TF-100 with many refills
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Anyone know what kind of pump I have?
    Well, the label on the pump to the right says its a Centurion (Magnetek?) Look over on that label for serial numbers, etc.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by frustratedpoolmom
    That is just the motor label. I have the same problem with my pumps...the motor labels are intact, but the pumps are incognito.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    11,969
    Oh, so looking that up won't tell you anything? That's just not right! LOL Why does it have to be so hard...
    kjdiver's Avatar
    Jan 2009
    Virginia
    69
    I did try looking up the info but it is just the motor information. I now know what replacement for that I need! Unfortunately I need to know about the wet side.
    I just figured out I need a new cover as there is super small whole right in the middle of the cover. Only can see it when turning the pump on/off quickly a little spout of water comes out. I wonder if I could maybe just epoxy the center?????
    thanks for the responses thus far! Anymore info is much appreciated!!!!
    May 2009
    Dallas, TX
    785
    Yeah, I had the same problem. The motor info was apparent but I had to look really hard to find pump info. If you haven't done so already, take a flashlight and look very closely all around the pump and you may find the answer.
    After scrutinizing mine, I finally found on the pump housing in very small letters: Sta-Rite.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Feb 2010
    North TX
    11
    Looks like a Premier pump, series 556N, should be a 6" lid o-ring. If it is a Premier pump, part # for o-ring is 33-489.
    Generic o-ring cross reference O-13 or an original Sta-Rite o-ring will work U9-46. Parts for this pump are not easy to come by. Lid and Clamp are obsolete. Hope this helps. Pump is old ! !
    Mike
    River Brook Pools & Spas, Inc.
    www.riverbrookpools.com
    Guest
    Quote Originally Posted by RiverBrookPools
    Ditto! I see these every once in a while still. Probably not worth spending a lot of time with. A new pump will be much more efficient, quieter and easier to maintain (but probably not cheaper than keeping the one you already have!).
    kjdiver's Avatar
    Jan 2009
    Virginia
    69
    I appreciate everyones responses and a big THANKS to Mike! I was able to do some searching with the info you provided and I think I found a few options for replacement covers. I do need a new pump but a new lid might be instore as I figure out the type of pump I should get (that may be a future thread after reading a bunch of existing threads).
    In the meantime, putting a bit of magic lube II in the center of the lid where the crack is makes the pump prime almost immediately. All the bubbles that use to be in the pot when the pump ran are almost non existant. This is my first pool and I'm learning tons thanks to TFP. Thanks everyone!!!
    kjdiver's Avatar
    Jan 2009
    Virginia
    69
    One more question as I'm feeling pretty dumb. The premier pump 556N looks close to my pump but there are a few things different so I went and measured. I measured 8" for the diameter of the lid on my pump, the listed dimensions for the premier pump is 6". Are the lids measurement the interior or the exterior measurement?? I just assumed outer diameter...
    I really need to get a new pump...without having to become a fluid engineer in the meantime...
    Thanks!
    Feb 2010
    North TX
    11
    I believe its from the underneath side of lid. Basically, inside dimension of pump pot ( where basket goes ). My pleasure. Glad I could help.
    Mike
