Results 1 to 15 of 15
Thread: In-Line Chlorinator for when I am gone?
    Aug 2009
    Lafayette Area, Indiana
    25
    This is my first year with a SWG and I am working on getting all the fittings and lines I need to plumb everything up. I have previously used an in-line chlorinator with 3" pucks. Should I plumb this in as well and just leave it empty except for when we will be gone? I am not sure how to plumb it in - should I have a bypass for the SWG so I can just turn it off when we leave? I have an Intex SWG and my concern is if the power goes off while we are gone than the SWG will lose its programming and not work.
    AG 24' Doughboy 13,500 gallons
    225 lb Sand Filter, Intex SWG
    Royal Spa Emperor II 545 gallons
    Feb 2008
    Denton, TX
    5,061
    Re: In-Line Chlorinator for when I am gone?
    You could plumb the tablet feeder in if you wanted to. Or, you could simply get a floater for about six bucks and just throw it in before you leave.
    Because you would use the feeder relatively infrequently, you might be better served by just using a floater since that would be one less thing that could develop a leak in the future.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I like the floater idea. We leave our pool unattended several times during the season. Our procedure has been to raise the FC to shock levels and turn off the pump before we leave, the concern being that we might have a power outage (common in these parts) and that a subsequent surge could burn out the pump. Yeah, pretty anal, I know, but it's what we do.
    Throwing in a floater, even with the pump turned off, is a great idea. It'll feed some chlorine into the water even if there's no mechanical circulation. I'm going to try that, and thanks for the fish!
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    22,548
    I'll go ahead and vote for the floater. Since you're plumbing everything I'd put a bypass in for the SWG even if I didn't install a chlorinator. That way you can still run the pool with the SWG removed by just turning a few valves.
    Aug 2009
    25
    If I don't plumb in the chlorinator, the flow will still go through the SWG when the pump is running, even if the SWG is not turned on, right?
    Will the floater work ok if my solar blanket is on?
    Vero Beach, FL
    462
    My SWG is wired into the pump timer and set to come on when the pump is on. It has the option to be its own independent timer, which at first seemed like a good idea until I thought about what happens when there is a power glitch. If you wire the SWG to the pump timer then it will be on every time the pump is on. We get lots of lightning and power blips here in Florida and when I go away on a week long trip I don't do anything special to the pool before we leave.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    22,548
    Quote Originally Posted by 4boys531
    Correct, but if for some reason you have to remove the SWG then you'll have to connect the inlet and outlet pipes in order to run the pump.
    Good question. If you placed it out under the blanket away from the pool wall it would still provide chlorine in that area, and that would still eventually get dispersed if it lasted long enough but free floating would be better. Maybe someone will have more experience with it and can enlighten us.
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Yes, the flow through the Intex is only determined by the pump, it will not be affected by whether the unit is programmed to operate or not.
    The solar blanket will probably keep the floater from moving about the pool, so I would try to place it in the middle. The area around the floater will have a higher FC, and if it sits against a wall might bleach it some.
    You can also use the tablet feeder with the Intex, that is what I do. You might need chlorine when the water is too cold for the Intex to generate much, and the tablets will also boost the CYA (which is good if it dipped over the winter.) The tablet feeder and the Intex are both designed for high FC, so it won't hurt them. It is usually recommended to put the SWG as the last piece of equipment in line.
    lborne,
    The main draw back to the Intex is that it lacks program retention on power loss. That's why I replaced the controls on mine - http://www.troublefreepool.com/the-a...wg-t19172.html
    Good Luck, and Best Wishes!
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Dec 2009
    Central Massachusetts
    2,690
    What kind of SWCG do you have? What makes you think it will lose its programing if the power goes out? Have you tested it to see?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    OP has an Intex, it does lose it's programming if the power connection is lost, and it has to be reset.
    Dec 2009
    2,690
    Quote Originally Posted by frustratedpoolmom
    Ah, ok. Didnt know that!
    Guest
    It will if you have a pool cleaner in the pool and you tie a string to it to drag the floater around! I like to suggest that for those that use the floaters so that they don't sit in one spot in the pool (like they tend to; right over a step and degrade the finish in that area!) and move the chlorine around a bit
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by simicrintz
    That's a great idea. That is unless you have a tempermental Baracuda like I do, in which case I could tether my floater to it and it would probably bog the Baracuda down and result in the degradation of the Baracuda finish! Funnies aside, that's a good idea.
    Jan 2009
    Cupertino, CA
    1,966
    No cleaner in OP's specs, and anyway I wouldn't tether a floater to the cleaner if there's a cover. Just park the cleaner under the cover in the middle somewhere. OP wasn't going to turn the pump off for the week, just the SWG.
    --paulr
    BBB "Intermediate Swimmer"
    Guest
    Quote Originally Posted by PaulR
    --paulr
    None in mine either, but I have one Didn't say we had to list everything we had on our pool
