Results 1 to 13 of 13
Thread: Re-Sizing an AGP??
    Re-Sizing an AGP??
    I grabbed a pool for really cheap ($100). Thought it was a 24' but turns out to be a 27'. My property & deck is set for a 24' from the previous owner.
    Can I simply install one or two less rails,posts, etc an end up with a 24' circle? Then re-drill the steel wall at the 24' mark.
    I really can't afford a brand new pool right now.
    36K gal, Tagleus TA60 sand filter, vinyl lined
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Re-Sizing an AGP??
    This is a very interesting question - I'll be watching to see what the response is. I assume you are planning on purchasing a new 24' liner?
    Keeping my fingers crossed for you!
    A new liner it a definite. It appears to me that that there is a simple reason as to why standard pools go 15,18,21,24,27, etc. Exactly 3' apart. They just use more supports & a longer wall to get the next size up.
    I could be wrong.
    22,544
    According to my pool. A 24' round with 16 supports all I'd have to do to make it a 27' would be to add 9' 5-1/8" to the wall and two supports and top rails. The math works out perfectly. I see no reason you couldn't remove 9' 5-1/8" from the wall and two supports & top rails from a 27' pool to make it a 24' pool.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Yup...anything is possible, but the only setback I would see is possibly the bottom rails needing to be re-shaped to match the new radius
    22,544
    Good point, dman. There might not be enough difference to matter but definitely something to consider.
    Thanks. I'm going to give it a shot.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Take lots of pics! Maybe you have started something new!!
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Casey's Avatar
    SW PA
    10,427
    Tip of the day...
    Measure twice cut once!!!
    Good luck!
    22,544
    Quote Originally Posted by Casey
    Tip of the day...
    Good luck!
    Dangit! That's what I've been doing wrong. I've cut this thing 3 times and it's still too short!
    Seriously: Good luck and do take pics along the way.
    I think I'd start by laying out the upper and lower rails for the 27' layout, then take a water hose or something else you can easily shape into the circle and lay it inside at 24' radius (measure between the two all the way around to get it perfect. Then, you can begin "building" the 24' radius with the parts you have and adjust from there.
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    Mar 2008
    Sudbury, ON
    28
    The only other issue I can think might give you a problem is where you have to drill the new holes...it won't have the rolled end that gives it more strength so that the bolts don't tear through the single layer. You could try bending the end back on itself and adding a strip of steel or something to give it some extra strength.
    Good luck with this...it is definitely interesting.
    15' AG - 48" walls and center dished out 8", 1 HP Hayward , Jacuzzi 225 sand filter, and Taylor K-2006 kit.
    Quote Originally Posted by Northcountry
    My new/used pool I just picked up had a 3/16" x 52" x 2" strip of aluminum on both sides of the seam for support. You can get that at lowes or hd and drill it.
    Richard
    Temecula, CA
