Thread: Polaris booster pump with keyed motor?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Another pump motor question...
    I have a booster pump that appears to be a Polaris (PB4-60 maybe?).
    The motor is labeled AO Smith SK1072 which is Nema-C flange 56C keyed.
    Everywhere that I have seen replacement parts for polaris booster pumps calls out for threaded (not keyed) and specifically the B625 which is a 56CZ frame.
    Is it possible that I have an older model?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Pacifica's Avatar
    Mar 2010
    San Diego, CA
    47
    Re: Polaris booster pump with keyed motor?
    All you need is a c-framed keyed shaft motor. You can purchase the type of motor at any pool retail spot. Just remember to specify the correct horsepower when you buy it.
    22,553
    It is possible that you have an older model. I, like you, could only find manuals that referenced the threaded shaft units. The oldest one was dated 6/03 the newest one was 6/06. I didn't find anything newer or older than that.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Bama, do you happen to know if the shaft seal and gaskets were the same on the keyed shaft version?
    22,553
    The SK1072 has a 5/8" shaft and so far I can't find the dimensions for the B625 but it being a 56C frame means that it has a 5/8" shaft also. I'd say the seal & gaskets should fit but that's just a educated guess.
