Hello Everyone, sorry for the absense but I've been awaiting the arrival of the new lid that I ordered last week. In the mean time, I've been trying not to focus on it because as another member is threatning to do, I too think it could be a good idea for my problem "throw in the hand grenade"... (funny but true)
The lid will be in today and when I get home tonight, I'll see what happens. As to answer the last several questions you all had:
Does the lid top screw down into the basket? No, it doesn't screw down, just slides down into place and then you turn into the lock position.
If the lid is not all the way down it will leak. Also check and make sure the lip of the pump pot is not cracked or broken. The lid is pushed all the way down and locks into the correct position so that the notches on the side of the housing are at the place they should be. Also, I have put plenty of magic lube on the o-ring so that shouldn't be the problem. The housing is new and I don't see any cracks.
1. The lip where the o-ring fits on the lid is broken. This should be really obvious. Hum, the lip you are speaking about, is that the indention that the o ring sits down INTO on the lid not on? Because mine sits INTO an indention on the lid not on the lid without the indention. Confusing I know.
2. You're using the wrong o-ring, or the o-ring is shot. The manual should tell you which o-ring you need. I went to the pool supply by my house and purchased a Hayward o ring and still got the same leak. I then went to a different pool supply and purchased another o ring and they are identical. I then went to a local manufacturer/distributor of o rings and took the lid and ask if they had something a little bigger and they said nothing bigger around would work because then I wouldn't be able to close the lid. :grrrr:
3. The housing itself is cracked, and thus spreading open as you mount the lid. I would expect you to see a leak wherever that crack is though. The housing is new and the leak is the same with the new housing or the old one (which was new last season)
From the lid sliding into place so easily with little to no pressure makes me think the problem is the lid. When I get home tonight and after replacing the lids, if I still get the leak, I'll move onto check the pressure again to see if that's the problem.
