Thread: opened pool, slightly green water, starting to shock it
    May 2009
    Jasper, TN
    249
    I know this has probably been asked a million times, but just a little nervous as this the first 'opening' I've had since we got the pool last summer.
    I don't have all the numbers yet, but the main thing is I need to triple check on it the CC.
    CYA is about 35
    used walmart kit for PH test, used a little muriatic acid to drop the PH to what looks like 7.4 on the chart.
    I didn't use pool calc yet as I knew I'd need a lot of bleach to start with since it was a little green (cover slipped in pool over the winter but kept it from becoming a total swamp).
    Right now, used fas/dpd test, FC=12 and CC=0
    water is not sparkling clear but not what you'd call cloudy either, no green left of course.
    So do I need to go up more and keep it shock level? or is ok to let FC fall back down? I'll be adding more CYA once shock is done so my target will change as I adjust CYA.
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: opened pool, slightly green water, starting to shock it
    Post a full set of numbers if you can.
    If your CC is truly 0, then it looks like you got the algae. If it were me, and it wasn't sparkly yet, I'd keep the FC up for another day, but you can let it come back down to normal levels.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Did you do an overnight FC loss test? To see if the FC is holding overnight - then you'll know if you are done shocking and can let it drop down to normal, letting the filter do the trick. But you have to confirm that first thru the overnight test. IF the FC holds overnight, you could try a little DE in the sand filter to help with clarity - instructions are in pool school.
    30,403
    You are finished with the shock process when..
    1. Your pool water is sparkling
    2. Your CC's are .5ppm or less
    3. You can hold your FC overnight without losing more than 1ppm.
    Get that pool water sparkling....keep the chlorine up!
    May 2009
    Jasper, TN
    249
    I couldn't find r12 to do CH test. It's an AGP with vinyl liner though.
    CYA = 35
    FC = 12.5
    CC = 0
    PH = 7.4
    TA = 60
    I will do overnight test tonight/in the morning.
