Results 1 to 7 of 7
Thread: CYA and backwashing
    Jul 2009
    Charlotte NC
    31
    CYA and backwashing
    Just opened the pool about a week ago and with a little TLC got it back to blue and clear. I took a sample to my local pool guy and as I
    figured some of my numbers need a little tweeking, as expected. My question is with my CYA a little low (55ppm) and the fact that it is
    SNOWING POLLEN , I literally have to backwash once a day. I know this because I've done it the past 4 days and the water that comes out
    is nasty. How can I add stabilizer if your not supposed to backwash for a week after adding it?
    16x34 kidney shape 19,000 gal vinyl IG
    Pentair IC-20 SWG
    Pentair sand filter
    Pentair 1HP pump
    30,432
    Re: CYA and backwashing
    Tie it up in an old sock and suspend the sock in front of a return.
    Jul 2009
    Charlotte NC
    31
    What should I tie up?
    Pentair IC-20 SWG
    Pentair sand filter
    Pentair 1HP pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Put the stabilizer in an old sock and tie it so it hangs in front of where the water returns to the pool from the pump. It will take several days to dissolve. You will also need to wait about a week after adding stabilizer for it to be reflected accurately in the test results.
    Love TFP? Become a
    TFP Supporter!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, you read correctly. A sock. like an old tube sock or dress sock. Pour in the granules, tie a knot at the top, and use some string to hang the sock in front of the return. the flow of the water will make the granules dissolve and you won't lose any to backwashing.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I use one of my wife's knee-high nylon socks. They will expand enough to hold just about any amount you need. Then tie a knot in the top and drop it in the skimmer.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    22,553
    The only issue with putting it in the skimmer, with him backwashing so often is that he'll backwash a lot of the partially dissolved out. In this case it's better to hang it in front of a return then he only loses a little during backwash.
