Results 1 to 8 of 8
Thread: Low PSI on Pump
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    Low PSI on Pump
    My tale continues with opening the pool this weekend and as usual I'm turning to my trusty, helpful sources here. Attached is a pic that show the current PSI on the pool pump. This reading seems low to me, compared to the previous 2 years. However, the force of the water coming out of the return seem to be just fine. Is it possible my guage is reading faulty?
    30ft round AG pool
    2 HP pump
    Sand filter
    [attachment=0:2xk02qwz]Pool PSI.jpg[/attachment:2xk02qwz]
    Alan
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Low PSI on Pump
    Yes, gauges do go bad. You can pick up a replacement.
    Does the gauge go to zero when the pump is off?
    Is this a 2 speed pump? My gauge reads about 3-4 on low but 15-16 on high speed.
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    Re: Low PSI on Pump
    It does go to zero when it is off. It is a single speed pump. Last season it routinely stayed in the 12-14 PSI range on the low side after backwashing.
    I've read that it's possible for the filter basket to be clogged before the pump itself or for there to be a blockage there?
    Cheers.
    IrishAl
    Alan
    30ft AGP
    2hp pump
    22,537
    Re: Low PSI on Pump
    The gauge could actually be reading below zero but the stop prevents you from seeing it. Gauges don't usually fair well over the winter. I would change it out for peace of mind.
    30,395
    Re: Low PSI on Pump
    Changing the guage is a cheap, sure-fire way of confirming your pressure is low or the original guage was bad.
    Assuming the pressure is truly low, you have a restriction somewhere between the main drain/skimmers and the pump impellor. That is called the "suction side" of your plumbing.
    The impellor could be clogged, a valve could be half closed, or something could be stuck in one of the pipes or it could be something else but it is in your suction side plumbing. I would suggest starting at one end or the other until you find the restriction.
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    Re: Low PSI on Pump
    So I have to add the happy conclusion to this tale. I got a replacement pressure guage, put it on and still identical to the old one (4-5PSI). Soooooo I plug up the pool, and start pulling apart the pump. I cleaned the impellar (which appeared just fine), the filter basket, the lines etc..etc. I put the pump back together and began to connect the hoses back up to the pump when I noticed.....I had the hoses connected to the filter backwards!!! Meaning i had orginally hooked up the hose that goes to the pool return to the pump valve. Yes I'm an idiot!!
    As soon as I fix them, and turned pump back on normal pressure was restored at 13PSI!!!
    Needless to say
    Alan
    30ft AGP
    2hp pump
    30,395
    Re: Low PSI on Pump
    Every issue with a pool turns into a learning experience. Having gone through that clearing procedure, you probably know a whole lot more about your system than you ever did before. I am really glad you found it.
    11,969
    Re: Low PSI on Pump
    We won't flame ya. We've all had our "special" moments.
