Thread: how to tell if gauge is broke or pump about to blow?
    May 2009
    Jasper, TN
    249
    I just uncovered the pool today and adding water (drained it below the return over the winter).
    When it had enough water I turned on the pump and everything sounds normal. But the gauge on the sand filter is maxing out at 100psi. I backwashed for a min but it wasn't dirty and psi didn't drop.
    Is it just a bad gauge you think? Anyway to tell for sure other than just buying another gauge?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: how to tell if gauge is broke or pump about to blow?
    Definitely a bad gauge. The pump cannot produce 100 PSI.
    Mark
    May 2009
    Jasper, TN
    249
    Ok good. So there's no harm leaving it running until a new gauge gets here?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Just to be sure you aren't harming the system - how's the return action? Make sure that the valve(s) for the return(s) isn't closed. Also check to see if the gauge goes to 0 when the system is off.
    Luv& Luk
    -Ted
    May 2009
    Jasper, TN
    249
    You know, the most common sense thing would have been to see if it did go to 0 when I was outside and I thought of that as I was sitting down right before reading your reply LOL I did not check.
    But there's plenty of return. I am confident it's operating exactly as it did when it was off.
