Thread: Rookie from Houston, Tx checking in. . .
    Apr 2010
    Shoreacres, TX
    I recently purchased a home with a 16,000 gallon IG plaster pool and 36sqft DE filter. . .even more recently I've discovered that I don't know squat about pool maintenance so here i am!!! I'm sure I'll have some questions for you guys/gals in the near future so I wanted to introduce myself first. I'll be sure and do my research before posting too many redundant threads/questions and I'll always try to post test results(those that i can currently test anyhow). Thanks for having me here, I look forward to learning from this forum and enjoying my pool this season. . .I'm already enjoying the 72* water temperature that I have down here in Texas!!!
    16K IG Plaster Pool w/ Hayward 36sq.ft. DE filter I'll have to add the pump info when I can get to it.
    Testing with TF-100!!
    Feb 2008
    Flower Mound, TX
    Re: Rookie from Houston, Tx checking in. . .
    Welcome to TFP! Let us know when questions arise. We're here to help.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    Mar 2010
    Spring, TX
    What area of Houston are you in?
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Butterfly's Avatar
    South Carolina
    Hi jetcycles and welcome to the forum
    You're done SLAMing when:
    Feb 2010
    Houston, TX
    Hey jetcycles, nice to see someone else in the area! Well, it's not quite the same area as you, I live about 45 minutes north of you up 146. I used to go through Shoreacres on the way to Kemah all the time! Small world...anyways, hope you get that pool cleared up soon!
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
