OK so I just picked up a 2nd FAFCO Solar Bear panel and want to plumb the two in parallel (on the ground, next to the pool and filter. The question is to make the conections, is using a WYE (Y) fitting better than a Tee (T) fitting in terms of allowing maximum flow, or does it make any difference?
I can get 2 -1.5" Wye fitting at a total cost of $27 shipped vs. buying two T's at home depot for probably $5-10 bucks and was wondering if the Y's are worth the additional cost?
