Thread: Loss of suction
    Loss of suction
    I have an old in ground pool, probably built in the 50's. I installed a Pentair whisperflo 2 speed pump last year and everything went pretty smooth. I also have a 48 sq. ft. DE filter with new grids. All of the original lines appear to be 1 1/2".
    Everything was running normal last week, I did have a couple of small leaks but I took care of them. Here's the problem, when I start the pump everything is fine for about 10 seconds and then it will lose suction then it will build pressure and then lose it. This cycle will continue over and over. Again, no discernible leaks, filter is clean and the water coming into the pump is clear (no dirt).
    Does anybody have any suggestions?
    Trace
    19,600 to 22,500 gallon plaster pool. (Every calculator is different)
    1 1/2 hp pump Don't know the flow rate
    Polaris 280
    Real POS Laars LX Low NOX 400k heater (5 years old and it's DEAD)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Loss of suction
    Check that the water level is high enough in the skimmer and that the skimmer door swings up and down freely.
    Re: Loss of suction
    Thanks for your quick response, the water level is high enough so that the skimmer door swings freely.
    Anything else to check?
    Trace
    Polaris 280
    22,553
    Re: Loss of suction
    Are you seeing air in the pump basket? Sounds like you have a suction leak somewhere. Start by checking the pump basket lid. Make sure the o-ring is lubed. From there it's a matter of checking the suction piping from the pool to the pump.
    Re: Loss of suction
    Got it fixed. The skimmer door was hanging and blocking some of the water from entering the return. I feel like a newbie, maybe because it's the beginning of the season.
    Thanks for everyones help.
    Trace
    Polaris 280
