Results 1 to 7 of 7
Thread: Solar panel install question
    Pipe question.
    I have 2 inch pipes for the pumps, However my Solar panels are 1.5". I have a pretty long run to the panels. 1.5 inch would be easier to work with since weight and cost is lower. Should I run 1.5" pipe up to the roof or use 2" pipe then reduce the diameter at the panel.
    layout question.
    the way my roof is to the equipment pad. I have 4 2x20 panels. To have it self draining I need to install the panel
    Horizontally - water flowing across side ways. or strap the panel over the apex of the roof.
    Can those configuration work?
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Solar panel install question
    I would go with 2" pipe to keep the friction loss down.
    As for the layout it is hard to visualize what you are considering but I do not understand why you need to install the panels horizontal to have them self draining. Panels will drain from the vacuum release in both directions and the draining process creates a vacuum which will help drain the panels and suck most of the water from them but you can still get some water trapped in the plumbing if there are local high points so you will want to avoid that if possible. Normally, you will just need to tilt the panels only slightly toward the supply line so that the water will naturally flow toward the pipe. Both the return and supply pipes should have a slight tilt along the roof toward the pump.
    Here is a good illustration on how to tilt the panels.
    I fixed the link. JohnT
    Mark
    South Central NJ
    3,192
    Mark, 404 Error, Page not found.
    Scott
    Owner of - PoolGuyNJ LLC
    Vero Beach, FL
    462
    If they are the fafco panels you must install them horizontally. Check their web site for installation diagram that shows the slight pitch (1" per 10' I think).
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    mas985's Avatar
    Pleasanton, CA
    11,737
    Thanks for the link check and fix.
    As for Fafco panels, this could be definitional but they show them verticle in the manual here and also shown here. I know that EDPM panels are usually installed horizontally and so are the above ground panels but the polypropylene are normally installed vertically. Doesn't mean that they wouldn't work the other way but that is what I have seen them installed most often.
    Mark
    Vero Beach, FL
    462
    Quote Originally Posted by mas985
    That's the 12' panels shown in the pics. I'm talking about the fafco sungrabber 2' x 20' panels- which is the size the OP noted he had. See installation manual here that specifies horizontal installation only. http://www.inyopools.com/owners_manual/ ... ground.pdf
    If you have a warranty issue, they require a photo of your installation to make sure you did not install them vertically which would void the warranty.
    Solar heat
    I have the smartpool sunheater panels from costco. 2'x20' Looks like I have to do a Vertical installation. That part of my roof is not 20' wide.
