Thread: Pump has small leak
    Mar 2010
    Spring, TX
    1,082
    Pump has small leak
    I took apart and cleaned my DE filter. I put it all back togeher and I had leaks where the rubber seal is between the top and bottom. So I got some sealant and put it on and let it set for two days to get nice and dry. I had no leaks for about a week and now have a very small leak on the side. It is a very slight leak and some seems to dry before it goes all the way down. I know some of it hits the groud due to it being wet around the pump. The pressure is doing fine with no issues. Is this something I need to fix right away or can I jus wait until it really starts to leak if it does and then I would think I need a new seal. I am also thinking maybe I put too much sealant and it was not an even coating and that is causing some of the leaks. I can take pics tonight if need be.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Pump has small leak
    What model is your filter?
    Mar 2010
    Spring, TX
    1,082
    There should be a large rubber o-ring that seals between the two halves of the filter housing. I believe it is part #34 in the diagram you linked to. You should open the filter up and clean and lubricate that o-ring with a silicone plumbers/pool lubricant. Also check that it doesn't have any nicks or cuts in it. If it does, it needs to be replaced. Also, when tightening up the clamp ring, tighten it as much as you can easily, then tap lightly with a mallet or hammer on the clamp ring all around the filter, and tighten it again. This tap/tighten process may need to be repeated several times, depending on what condition everything is in.
    Mar 2010
    Spring, TX
    1,082
    Is the O ring something I should be able to pick up local? Also what does the tap/tighten exaclty do? I am guessing it readjust the clamp tightness? I may go ahead and replace the O ring. When I lubricate it, do I need to lubricate the ring or the part of the pump it sits on. Such as the metal?
    Thanks.
