Thread: Cut Solar Cover with Polaris 280
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    I have seen discussion here about solar covers being cut into pieces for easier handling.
    I have also seen discussion about using a polaris (or other pressure side cleaner) under a solar cover (which I am current doing and it works fine).
    What I haven't seen is anyone who has cut their solar cover AND uses a polaris cleaner. I am thinking about doing just that. My fear is that the polaris hose will move the pieces around and push them onto each other.
    Does anyone have experience doing this?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock ('s a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jan 2009
    Cupertino, CA
    Re: Cut Solar Cover with Polaris 280
    I have one big piece and one small piece, and the small piece is smaller than the area that was left over; that is, if I snug it up against the big piece and one wall, there's a 1-2' gap along the other wall. So the small piece has lots of wiggle room. It doesn't get pushed up onto (or under) the big piece; the Polaris hose doesn't have enough oomph to make that happen.
    Based on watching and thinking about the way the hose moves, if I had two more equal-size pieces (which is my plan for the next cover), I would prefer to cut the cover so the cuts are parallel to the wall where the Polaris hose is attached. That way the hose is unlikely to pop up between pieces.
    BBB "Intermediate Swimmer"
