Thread: A few quesitons, CYA, chorine and sand from filter in pool
    Jul 2009
    a few miles south of New Orleans Louisiana
    16
    Hi all,
    Just opened pool and had to add CYA since I drained and refilled just before closing to find and patch a hole. I have the solid CYA in a sock bobbing in front of the return, enough to get the CYA level up to around 30 or so.
    A few questions
    How long should it take to dissolve?
    Also, can I add bleach while it is dissolving?
    Lastly I am getting sand from the filter on the bottom of the pool. I have vacuumed a few times and it keeps returning to the bottom of the pool. What can I do to fix or prevent this from happening?
    12 x 24 6800 gallon Voyager LX AG pool, 1.5 HP motor with sand filter, solar cover and a TF-100 test kit.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: A few quesitons, CYA, chorine and sand from filter in pool
    Yes, you can add bleach. I expect it will dissolve within 24-36 hours depending on the flow. YOu can squeeze/manipulate the sock with your fingers to speed up the dissolving....
    Sounds like something inside the filter maybe loose or cracked allowing the sand to get thru. You'll have to open it up and check to see if the parts are all intact and working properly. Are you sure it's sand?
    Jul 2009
    16
    Just to add the water is clear I don't see any algae other than some sand on the bottom of the pool. I'm running the filter all the time right now.
    FC 15 on Friday as I shocked that morning with some leftover trichlor and tested that evening, 0 as of yesterday evening. I have a few leftover pucks in the automatic chlorinator which I assume is adding at night and then depleating in the sun. I'll add bleach if it's safe.
    CC .5
    Ph 7.5
    CYA 0 before I put the sock in it. I'll test CYA again next weekend.
    Jul 2009
    16
    Pretty sure it's sand. It has a greyish beige color and it appeared within an hour of turning my filter on for the first time.
    11,969
    Sounds like you have a handle on things
    Good luck with the filter-hope it's nothing too serious.
    Jul 2009
    16
    Thanks, I'll tackle the filter this weekend.
