Results 1 to 13 of 13
Thread: help - how to add vacuum line
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    I'm thinking of moving my equipment pad to another area of the yard. While I do this I'd like to add some type of ball valve to the current lines (which have none) and a separate line for vacuuming. Would the vaccum line be possible? What type of valves are recommended? Any suggestions or advice, as always is greatly appreciated!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Re: help - how to add vacuum line
    Adding a vacuuming port to an above ground pool is fairly simple. If it is alright for the port to be outside the pool it is especially simple.
    I like particuarly like Jandy NeverLube valves, though many less expensive choices would also work.
    esim13's Avatar
    Oct 2009
    320
    Hi Jason, I'm a newb so I have to ask what do you mean by port? I just want to make sure I'm clear on this. Also would this go through the same panel that the skimmer and return are cut through? then join the return line at the pump? with each line having it's own valve?
    GEAUX TIGERS!
    Pics taken 2012
    22,542
    I'm not Jason, but by port I'm sure he means the place you plug the cleaner into. It'll be an adaptor on the end of a pipe for the hose to connect to.
    One thing we need to get straight is whether you have (or intend to buy) a suction or pressure side cleaner? It matters how the "port" is plumbed.
    esim13's Avatar
    Oct 2009
    320
    I have a Barracuda, similar to the Ranger model. So.... what next?
    GEAUX TIGERS!
    Pics taken 2012
    22,542
    Sorry I'm just now seeing this.
    That is a suction side cleaner. The most normal place to attach those is the skimmer. I have a zoom and a plate that sits in the skimmer over the basket that way you don't give up the basket when vacuuming.
    You can add a suction line and if you don't want to cut into the wall you can plumb it above the wall. The only problem with that is that there will be several inches of pipe above the water line and therefore will tend to get air in it.
    I did this exact thing a few weeks back. I just put a T with a valve suction side and I use this for my vacuum. I'll see if I can get a picture of it to show you how I set it up.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    esim13's Avatar
    Oct 2009
    320
    A pic would be great Denis. Thanks!
    GEAUX TIGERS!
    Pics taken 2012
    Quote Originally Posted by esim13
    Ask and you shall receive!
    Clearwater, Florida
    Hi Denis
    Does the vacuum line not take take on air when its plumbed in like this? and if it did would it real pose a problem? Thanks, I'm trying to learn from the pros!
    30 foot round AGP (25k gal), 2.5 hp pump, Hayward cartridge filter, Diver Dan pool vac, TF-100 Test kit
    -It takes less time to do things right then it does to do it again.
    Aug 2007
    near the swamp
    806
    yeah that seems like it would impose an air leak
    22,542
    Depending on how well the hose cuff fits the fitting it might be fine. The only problem you may have is in the future when the hose cuff expands or contracts it may not fit as well but then you cna always replace it when that happens.
    Aug 2007
    near the swamp
    806
    What's up with the uncovered junction boxes?
