Thread: How do I get rid of grit?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    My composite roof sheds little bits of grit when it rains, and some end up on the patio, and some of those end up in the pool. There's an annoying sand drift in the spa when everything settles down. It's not a lot, I could probably count the bits if I was patient. The vacuum won't pick them up. I attacked them directly with the vacuum hose and they moved, but didn't get sucked away. They appear to be too dense or something.
    Does anyone have any ideas how to remove this stuff? I don't relish the thought of diving with a pair of tweezers to clean things 100%.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: How do I get rid of grit?
    Can you put a gutter on that section of the roof?
    Love TFP? Become a
    TFP Supporter!
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Do you have a wet/dry shop vac?
    I've never done this before(disclaimer), but I hear you can configure your valves so that the suction comes from the spa drain and put the return valve to the pool. That will drain your spa into the pool. Do your necessary work with the shop vac, then reconfigure valves to suction from the pool drain and return to the spa to fill it.
    Hopefully the experts can confirm if this is a good idea.
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by tsunami
    I thought of that myself, I had the valves set to pool only when I was vacuuming and dropped the spa about 9" while I was chasing the bits around. I'm not sure if it's a good idea, either. That's a whole lotta water leaning against a 6" thick wall with nothing but air backing it.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    spill over spas can be empty while the pool is still filled. I wouldn't worry about a wall collapsing
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
