Results 1 to 7 of 7
Thread: Need to purchase a heater
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Well, now that we purchased a pool package, we feel that a heater will be needed. The grandkids might not mind the cold water, but I don't think my arthritis will! We have a gas well on our farm, so have free gas up to a set limit which we only use half of. So, a natural gas heater seems like the way to go. Any suggestions on size and brand? Pool will be a 30 ft. round, ag, 52" high. Thanks!
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Need to purchase a heater
    Versa 130 from Raypak
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Do you know what your gas reserve is in BTU's? Pool heaters are gas hogs. Most House furnaces and water heaters together are less than, or about 100,000 btu's. Most pool heaters require anywhere between 100K and 400K btu's. If you get too small of a heater to accommodate your reserve, you may not be happy with the performance (slow heat rise). Not to mention what could happen to your well, I don't know. Best to have someone in the know to come out and check the availability of gas (in BTU's) for the new heater. Then go from there.
    Keep in mind that if you put a heater in that is overrated for the available fuel, the heater will still fire and appear to work, but can soot up over time, and may not present this problem for some time thereafter. Oh yes, and the efficiency will be reduced, unbeknown to you (wasting gas).
    Factory Warranty Station for:
    linda1's Avatar
    Mar 2010
    Western Pa.
    300
    Thanks Pool Clown. This is over my head and I have no idea what you mean by gas reserve, so I will give your information to my husband. There are three homes on our gas well and we have never had any problems with it.
    We called the dealer we bought pool from and asked what size heater we need for the 30 ft. round. They said 150,000 btu. My husband has doubts that that would be large enough. I found a formula online so will also give that to DH and let him see what that comes up with.
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    We have similar sized water volume when you consider the depth of the pools.
    My 150,000 btu takea an awfull long time to heat up my pool.
    Knowing what i know now i would have gotten a 200-250,000 btu heater. Good thing is ai have found a local company selling demo's from pool and spa shows for half the price.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    You might consider using a solar system in addition to the gas heater. They are cheap, and even here in MT, can work very well to maintain the water temp. That way, you could use the gas for the colder times, but in July/August heat, the solar will likely give you as much heat as you need, or close to it. Something to consider. I actually just picked up 4 20' panels on clist for $150, so deals can be had.
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Quote Originally Posted by linda1
    I'm sure you have heard the phrase: going to the well one too many times. Your well probably has a BTU rating. How much gas it can supply in terms of volume. Just make sure that the heater you get won't over burden the well.
    Having said that...
    We called the dealer we bought pool from and asked what size heater we need for the 30 ft. round. They said 150,000 btu. My husband has doubts that that would be large enough. ...While 150K may be "properly sized" for your pool, a larger heater may give you more of what you are looking for in terms of heat rise over time. I have a heater that is way oversized for the pool but the time it takes to heat up is a fraction of the time a "properly sized heater" would take. And it is cheaper to run (cost of gas) because although it uses more gas (say per min.), it too only has to run a fraction of the time to achieve the same result.
