Thread: Return Jet
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    Return Jet
    I wanted to experiment with the return jet and I can't move it. I've tried loosening it but I can't get the wrench around it. I guess I need a bigger wrench. Any suggestions as to what kind? When I do finally get it should the it be so tight that I cannot move the eye?
    Thanks!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Return Jet
    No it shouldn't. Happens to me too tho. You can try some silicone lubricant, marine type on the eyeball part to see if that helps.
    esim13's Avatar
    Oct 2009
    320
    Re: Return Jet
    Thanks 'frustrated pool mom'!! It's almost 2 years since I've had the pool installed and I'm just starting to get into all the details.
    Special thanks to TFP and all those involved!
    GEAUX TIGERS!
    Pics taken 2012
    Re: Return Jet
    You want a strap wrench. They have a strap, often rubber or heavy cloth, that wraps around the fitting and lets you apply some leverage.
    Older eyeball fittings often become jammed. Silicone lubricant, as frustratedpoolmom suggested will take care of it once you can get it apart. No mater what you do, it will be a little difficult to move. You want it to stay in place when you have it where you want it, so there needs to be some friction.
