Results 1 to 15 of 15
Thread: No Vacuum to Waste - other options
    My plumbing is such that I do not have a valve that I can turn in order to vacuum to waste - it all has to go through the filter. Are there any other tricks that I am not aware that would allow me to bypass the filter when vacuuming? Or are there any inline filters that catch junk?
    thanks
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: No Vacuum to Waste - other options
    There are skimmer socks, which stretch over the basket in the skimmer. If you are after large debris, make sure your vacuum hookup lets you leave the basket in place.
    Well, my vacuum hole is under my basket so I have to remove the skimmer basket when vacuuming...
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    You can also use an inline leaf canister, that will catch things that will fill up your pump basket in a hurry!
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Can you tell us more about your system? There are ways to vac to 'waste', even if you don't have a valve for it.
    Luv& Luk
    -Ted
    SW Indiana
    9,199
    Quote Originally Posted by robmaxfli
    You need to use a vacuum plate so you can leave the basket in place.
    Here's a pic of my setup if that helps:
    What some people, with setups like yours, do is to remove the top of the filter housing. Then the water will overflow out of the filter and onto the ground, a messy but workable approach to vacuuming to waste. In practice, a leaf canister is probably a much better solution for most situations.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    My vacuum hole is under my basket too, but I have lots of gum tree "balls" that make me hesitant to suck up directly into the plumbing. So I use a skimmer vacuum plate and place directly over top of skimmer basket.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    So I'm guessing that you put that over your basket and then connect your hose to the top of it...Do you still get strong vac. suction from such a setup?
    SW Indiana
    9,199
    Yes. It's the preferred way to go since it cuts the risk of a clog in your line back to the pump. It completely seals the skimmer, so all the flow is through the hose.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Do you have a traditional vac hose/vac head that attaches to a pole?
    Yes -
    11,969
    Never mind...I'm sorry - checking your older posts I see now this is an inground pool. What I had in mind probably won't work for an inground, cuz of gravity etc, if you were to prime the hose to get a syphon action going, the hose wouldn't stay primed, would it?
    Can you add your pool specs/equipment to your signature.... go to User Control Panel, top left, then Profile, then Edit Signature. Thanks in advance!
    Mar 2007
    4,160
    (just a quick $.02 & )
    Whoever plumbed that filter 'valve' is an idiot!
    Luv& Luk
    -Ted
