Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: The Dragonfly Skimmer
    I just ordered a Dragonfly Skimmer.
    I've been quite happy with my Polaris LCS barracuda combo, and am eager to see if this single device can indeed do as good a job.
    Obviously it cannot pick up material on the bottom, but theoretically said material doesn't get there to start with.
    This seems to only make sense to me if the pump is run 24x7 which can become an economic problem.
    I will be running low wattage tests to determine the rolloff point at which it becomes ineffective and will post these and a video similar to the one for the polaris LCS. Currently I can get decent but not stellar performance out of my combo starting at 350 watts.
    Well see........
    http://www.youtube.com/watch?v=JLdwxCZDvzI
    http://www.youtube.com/watch?v=kYN92oAcPgc
    Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Re: The Dragonfly Skimmer
    4 days now credit cards been charged....
    Dave
    Dragonfly arrived while I was in Vegas. 7 days after order.
    To be honest the inside of the unit next to the flapper looked pretty beat up. (See pict)
    It took a total of 15 minutes for me to set the unit up.
    So far so good, at 750 watts (1 HP or solar tap on) the unit is indeed a powerfull skimmer. Much more so than the wall unit, a poolskim unit, or the LCS component. It was pulling debris against a the wind this afternoon with surprising speed.
    The filter runs about 4lb of pressure higher at the the same rpm as the lcs g4 combo.
    Ill run low power effectiveness tests soon.
    Dave
    I just installed one also. However, I don't seem to find the right depth and optimal flow. I am running at 65 GPM and the three sides are about surface level so water channels through the center V of each channel. I don't see lots of flow or pick up. How is your setup?
    Richard, Temecula, CA
    28,000 Gal. In-Ground Black Marble Pebble Tec and tile, Intellichem with Chlorine and PH control, Pentair EasyTouch 8, ScreenLogic Wireless, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, Water feature spillover from SPA.
    Setup is a bit tricky- try this.
    try this first- Hold the thing upside down underwater- and get ALL the air bubbles out of the floats rock the unit side to side as there are 2 sets of holes in each float.
    Then if that doesnt work- Then raise the floats all the way up so the platform is as low as possible.
    This should start the flapper moving.
    I get the feeling though that this isnt a 100 workable device in every situation though.
    I took some video Ill post.
    Dave
    Thanks. I did all that and with the floats all the way up the valve stays closed. If I just raise one of the floats slightly (slight tilt) the water level goes u to just above the three sides and then it drops as the valve closes. Sees to work that way but the flow is not that strong.
    How low are the three sides below water level?
    Maybe you have simply too much flow?
    When I run mine at 750 watts the pulsing slows down and turns into a waterfall action with little to no pulsing.
    When I turn the pump rpm down and pull 450 watts - it starts to pulse.
    http://www.youtube.com/watch?v=Qv6EqDXOIw8
    Thanks. I will try again tomorrow. How far below the surface are the three flat sides?
    Quote Originally Posted by rmklaw
    If you go by the marks on the floats -the waterline is the 4th mark up from the bottom.
    Looks about an inch.
    This is of course with the pump off.
    Dave
    Re: The Dragonfly Skimmer - optimizing
    I can get this unit to perform very well at 260 watts of power @ 1950 RPM.
    At 1900 RPM the unit stops cycling all the way and water never flows over the top- so thats seems a bit to low.
    I could play with the speeds in 5RPM increments between 1900 and 1950 but I dont see the point at this stage unless I feel like being a complete propellerhead about it.
    The setting also works well up to about 800 watts of power and then stops cycling and just creates a waterfall effect into it.
    RMKLAW- The instructions talk about a "bypass" if you cant get it working, and based on what I learned I think at 65 GPM you may be pushing more than the unit is really designed for or it may just need further tweaking. It seems the lower tray being underwater is optimum for low flow since I can go down to this level. Maybe raise the flat side as high as you can for this much flow?
    Dave
    Thanks Dave. I will play with the flow since I can regulate the vaccum line where the skimmer is attached to.
    Guest
    Quote Originally Posted by Davegvg
    Dave
    Too late; you're already there Are you a motorhead as well? Something tells me you might be interested in quite a few mechanical things, not just this!
    Quote Originally Posted by simicrintz
    Dave
    Actually you are right!
    How'd you guess?
    Boats, dirt bikes, quads, toy haulers etc. toys are toys!
    Guest
    Dave
    How'd you guess?
    Nice looking floater My jet boat is long gone, but the Jeep and dirt bikes remain! Boys will be boys
    Thanks Sim! (we need to hook up!)
    As for the Dragonfly Its a REALLY effective skimmer,best Ive ever used actually - but I still need a bottom cleaner. Some stuff sinks quickly and misses, and the nightly shutdown allows surface floaters to land, soak and sink for an extended period of time.
    The australian site shows these components but the US site does not. I would be happy to purchase them from anyone who can duplicate this setup.
    If I can find a way to add the bottom cleaner- Ill have found the perfect suction side combo.
    Dave
    This device doesn't seem as consistent as say a bottom cleaner in regards to its performance at a given power consumption.
    I saw the unit basically sitting there doing nothing at its 260 Watt setting.
    To be fair water was moving over the edges, but the unit was not cycling up and down so it is "somewhat effective" when running like this but not fully.
    I bumped it 100 watts to 360 (about a half HP) and it came back to life and seems consistent at this level- but.... will it stay that way?
    This is turning out to be a rather finicky device.
    Uncle Dave
    Yaaay!!!!
    360 watts and the unit was fine today - This part is consistent.
    Boooo!!!
    Problem is that if I "juice" the solar tap speed any more than 2800 rpm, or more than 800 watts - the unit stops cycling.
    Although I this is enough for solar to be effective- the faster the water flows for solar the better net net - Im compromising performance for cleaning.
    Uncle Dave
    I added another 2 lengths of hose to see what would happen.
    The Dragonfly does an amazing job of moving around the pool-it makes a full circle in about an hour under all the ambient conditions Ive encountered in the last few weeks - to be honest I do not know why.
    There is very little directionality to my flow as I dont have eyeballs in the returns but am simply allowing them to dump straight into the pool.
    Ive settled on a 360 watt normal filter speed and a 700 watt solar tap speed.
    I get decent heating performance at this speed and the dragonfly is fully functional- any more rpm/watts and dragonfly starts losing efficiency.
    It also works out to a nice savings in that "full speed" is about 7% "cheaper" than my previous load and normal is about 50% cheaper.
    For the numerically inclined the specifics are- My pool hit 84 today at 1:30 starting from 77 at 8:45.
    Approx yield of 1.1M total BTU about 235K btu per hour off the solar.
    Surface quality is absolutely stellar -insects, fuzz, dust, helicopter, leaves, pollen anything that floats so far this thing has nailed. even at 360 watts it can pull debris against a breeze pretty well.
    I find I need to run the bottom cleaner about once a week for a few hours in my environment.- some stuff sinks too quick- not much though.
    the dragonfly lives up to most of it promises with only a few caveats quite nicely.
    An especially solid pool investment if you have control over flow.
    Uncle Dave
    Aug 2009
    North Central Texas
    1,358
    Uncle Dave, Where does all the debris ultimately end up? You may have talked about that but have to run and go work on my friend's pool, currently being initially "BBBed". Have to backwash and put in the new grids (my last year ones I don't need as have a new bigger filter). She's feeding me Sloppy Joes, something DH doesn't allow around here. (He's know as the "low carb natzi") So that part will compensate, somewhat, for the pain of working on her filter, with my bum knee.
    Anyway, if it ends up in the pump pot basket, I wouldn't be able to use one because of too much stuff, round the clock. That's one of the great things about the Pool Skim. It keep the stuff from going towards and/or into the pump basket.
    I'm glad you are getting it adjusted to your liking.
    I just went down to check my pump to see the number that are working best to keep my Pool Skim drawing pretty well. Inteliflo VF. Darn thing is really sensitive. Alerting that I need to backwash so numbers are not usual. It usually slows down the flow when that happens but still keeps enough to adequately supply the Polaris booster. The fine stuff I get in my pool, even with the Quad 80 is demanding a backwash weekly. The cellulose media doesn't let very much pass through. So contrary to what is claimed, with my microscopic stuff, and with the cellulose catching virtually all of it, my backwashing intervals have not gotten longer. It seems to work too well.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
  20. Back To Top    #20
    Good question GG.
    More than 50% of the time I use a hayward large capacity leaf canister-on the end of the first hose-I use the one with the plastic grate not the bag because I want the really small debris completely out of the pool, what slips through this usually gets hung up in my epumps filter basket - which is absolutely enormous- MUCH larger than my whisperflows basket.
    I find the actual size of the pump annoying, and not as well packaged as Pentair's offering- but the basket is waay nicer.
    Note: I had pentair whisperflow 1HP prior to this pump and I loved it, so the above comment is in no way a disparagement of Pentairs pump, but a realistic comparison of this particular feature along with its downside.
    I still have it as a standby replacement now.
    I havent had the dragonfly in full leaf season so I may find I need a Poolskim, or 2 before clogging - but thats later....
    Of course the polaris LCS I have has a much nicer integrated basket, but with limited capacity for the bottom cleaner, and the skimmer isnt nearly as good........
    I only need to backwash a few times a year, with a de 60 so my dust influx MUST be substantially less than yours (ouch! brutal) although Ill give you run for the money on helicopters!
    Careful on the "too well" you may jinx it!
    Uncle Dave
