Results 1 to 10 of 10
Thread: Way to tape-repair a pipe?
    I have a pipe on my return side with a very slight leak at a fitting. It's where a 1 1/2" pipe meets another, at the joint. The leak is slight.. I'd say if it lost a cup of water a day, that's a lot.
    Is there a way to seal this with some kind of tape? I've tried saturating the pipe in the blue wet PVC cement and it seems to help. but I still see water there occasionally.
    I'd hate to have to replace this whole piece of pipe if there's something quick and easy I can do.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    30,424
    Re: Way to tape-repair a pipe?
    You can try about anything but most, if not all, won't work. In the long run, cutting out the bad joint and replacing perhaps the whole pipe is the best solution.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    How about this,http://www.epoxyproducts.com/pipewrap2.html? Even shows a pool application.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Vero Beach, FL
    462
    I've sucessfully repaired small drips on PVC pipe using 2 part epoxies you can buy at Home Depot and such. They make some specifically for wet applications, but I think almost all will work. The trick is to rough up the pipe surrounding the leak with a bit of sandpaper and then press the epoxy into it and around the pipe.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    South Central NJ
    3,192
    Blow out and seal the line first. Any water there will likely interfere with the bond and seal. There are some underwater glues but I don't trust them yet, least of all in a pressure application.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2009
    Charlotte, NC
    539
    Magic Wrap from Lowes closed a gushing 1.5" PVC drain line- no lie. Pipe was not under water
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    Rubber cement will work as well. As long as its not dripping water while the cement dries. I would recoat it a couple times to be sure, But it has worked for me in the past for temp fixes.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    All good suggestions! I'll try the magic wrap today as I have to go to Lowes anyway.
    Clearwater, Florida
    Dec 2009
    Central Massachusetts
    2,690
    This is what you want to do. Only way to fix a leak.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    I ended up using some of the 2-part epoxy specifically for plastics and wet applications. It works! No more leak, no more bubbles.
    Clearwater, Florida
