Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: How my pool looked when I bought it
    Consider this the BEFORE picture. This pool sat for 3+ years before I got to it. You see the plastic sheeting scraps on the deck? The pool was full of it.
    I'll post some current pictures this weekend, after it's nice and blue.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Re: How my pool looked when I bought it
    Your pool looks something like my pool when I purchased my house a week ago. It will be a beautiful weekend for some pool work. I see some water entered into your light lens. Did you have to replace the whole light or was that something you fixed? I have the same problem with my light. Also, What model Pentair pool pump are you running? Can't wait to see the after pics!
    Thanks!
    Inground Pool/Spa 11,400 Gallons: Sq Ftg 412
    Aqua Pure 1400 Chlorinator: Aqualink RS controller
    Pentair Whisperflo Pump 1 HP EE-2 Speed
    Pentair Clean & Clear Plus 320 SF Filter
    2 inch plumbing: 1 Skimmer:
    Sunny South Florida
    I haven't done anything with the light yet. Come mid summer (and the ability to pay for it), I'll get one of those nice LED lights that Hayward makes and replace it. Until then, the light that's in there works and burns a bright orange color so I'll leave it in place for now.
    I ended up with a Pentair 3/4 hp WhisperFlo. It wasn't the WE-3 that I wanted, but it's the next model up that is slightly less efficient. It's been running for 2 days straight with no problems.
    Clearwater, Florida
    May 2008
    florida
    112
    Unfortunately there are a lot of pools like that since the foreclosure mess started. You have a nice clean up job ahead of you. Can't wait to see pics.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Gosh that's just disgusting... Can't wait to see the updated pics!
    WOW!!!!
    2003 Marquis Euphoria - 400gal
    Aug 2007
    near the swamp
    806
    I see potential!
    Quote Originally Posted by DBfan187
    I see potential!
    Me too! I'm hoping to get some new photos this week after the fence is up and I've got the bulk of the remaining dirt vacuumed out of the bottom.
    Clearwater, Florida
    Aug 2007
    near the swamp
    806
    fiberglass?
    fiberglass?
    Cement from the 70s.
    Clearwater, Florida
    Cleanup is really coming together. Now that my numbers are inline and the pool consistently holds chlorine, I'm really down to just removing the last of the dirt and leaves from the bottom of the pool. Here's some new pics:
    Clearwater, Florida
    11,969
    Very good! I expect much of the organic staining will continue to fade overtime... a little concerned with the VERY dark areas though.
    Boy that sure is dramatic were the Vac head has removed the gunk!
    The staining is pretty awful in some places, but most of the dark stuff you see is dirt/soot. If I run over it slow with the vacuum, it picks it up and reveals relatively clean gunite below.
    Clearwater, Florida
    11,969
    Excellent! (so hard to tell from the pics.)
    I'm just glad it's coming together now. I vacuum is for an hour every day, usually concentrating on getting the shallow end really good and pushing as much of the other debris to the main drain. Then I jump in to stir it all up
    Clearwater, Florida
    Casey's Avatar
    SW PA
    10,438
    I bet your neighbors are glad to see it cleaned up.
    That pool was a wreck! You've got her going good now!
    Feb 2008
    Denton, TX
    5,061
    Lookin good so far!
    The inner tubes are definitely a plus.
    GApoolmommie's Avatar
    Apr 2009
    Central Georgia
    16
    It looks great, even the fence looks 100 times better! I can't wait to see more pics.
    1) 26,000 IG, vinyl, cartridge, Polaris Auto Clear Plus SWG, Polaris 280 cleaner
    Bought the frog pond in Dec'08, and learned a great deal turning it into the beatiful pool it is now!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    amazing how clear it is even with all that dirt still in it. If it werent for the reflections and the pool toys/hoses floating I wouldnt thing it had water in it!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
  20. Back To Top    #20
    Dec 2009
    Columbia, SC
    34
    you have done a lot of work, can't wait to see more pictures too.
    18k gallon in ground plaster with attached spa
    Pentair CCP 320 cartridge filter
    Goldline Aqua Rite SWG
    IntelliFlo VS pump
    Teledyne Laars ESC heater
    Hayward Pool Vac Ultra cleaner w/ skimmer Vac Plate and inline leaf basket
    Palm Springs, CA
