Results 1 to 14 of 14
Thread: Best way to handle muriatic acid?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    The first time I added muriatic acid I got a big whiff of the fumes. It definitely gave me a respect for the stuff.
    I quickly learned to keep the wind at my back. I must look like I am golfing at Augusta with my finger in the air checking for a breeze.
    I pour out of the jug and eyeball the measurements because I decided I didn't want the extra handling involved with measuring cups, etc. Sometimes a little dribbles down the side of the jug, and I have to deal with rinsing it off.
    Is there any advice on how to deal with the stuff?
    What do other BBB'ers do?
    Am I making a mountain out of a molehill?
    Is this why you don't call it BBBM...because you don't want to scare people off?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mar 2010
    Spring, TX
    1,082
    Re: Best way to handle muriatic acid?
    The way I measure mine is I picked up a measuring jug from walmart for about 2.00. It measures up to 64 ounces. I got one for bleach as well. I know what you are saying about the smell and I have gotten wiffs of it before.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Respecting it is a great place to start! Gloves, eye protection and a gas mask are good precautions but you probably don't want to go through all that. The best advice I can offer is to make sure you remove the whole protective plastic/cardboard cap so it pours smoothly and doesn't splash too much. Close the lid tightly after use and dip the whole container in the pool to rinse it before setting it down anywhere. If you can use the whole bottle and dispose of the container, its much safer than storing a partially used container where children can gain access. Don't store it near chlorine containers or other chemicals.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    I know what you mean about being down wind.
    You can always wear heavy rubber gloves (used for working with chemicals) to protect your hands.
    Also, it don't measure but have learned that 1/2 gal will take the Ph from about 8 to 7.5 (no kid issues).
    I would also suggest taking out the cleaner before adding acid.
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Only advice I can give is (a) wear eye protection (splashproof goggles if you have them), and (b) try not to breathe the fumes. I do use a measuring cup, but to each their own.
    If the fumes get to be too much, you can always use dry acid.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jan 2009
    Cupertino, CA
    1,966
    I rest the jug on the coping, tilt toward the pool, hold the measuring cup right up to the mouth of the jug. It never splashes, because with the jug resting on the coping it's really easy to control the flow. But if it did, or anything slipped, worst is some excess acid would fall into the pool. I typically need only a couple of cups at a time so I do need the measuring cup.
    I don't take the polaris out but if it's right by the return I usually use, I would use the other one.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    San Rafael, CA USA
    12,082
    One can also get the half-strength Muriatic Acid (around 15% hydrochloric acid), hopefully at half the price, as it should fume a bit less.
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    If you use a measuring cup, be carefull not to set it on any concrete you have around your pool (until you rinse it.)
    I did that... once. Some acid must have dribbled down the side of the measuring cup, and started eating through the concrete.
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    30,432
    I have learned I don't need to be too exact in my large pool. I take the gallon jug of muriatic, lid removed, and partially lower it into the pool water directly above a return. I can then pour a reasonably accurate (but not precise) amount from the jug and the spout of the jug is only an inch or two from the water's surface. There is no splashing and the outside of the jus is automatically rinsed in the pool.
    This may not work so well in a pool with less gallonage as the measurements need a little more accuracy. I used to use a measuring cup but didn't like the extra handling involved.
    Feb 2008
    Denton, TX
    5,061
    I always make sure that I am upwind from the open jug when handling it. The worst days are when there is no wind and high humidity. In those cases, you have to be safe and quick since the fumes billow straight up and out.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by mynewpool
    I do this also - I use a 1 gallon rubbermaid pitcher and add water to it before my needed volume of acid. In other words, if I need 1 qt of acid, I'll first add 2 qts of water. That way, it is diluted in the pitcher before I carry it to the pool, and the pitcher isn't filled to the top as I walk to the pool.
    Quote Originally Posted by renovxpt
    This is also a key. I bought the cheapest ceramic knife I could find on ebay to cut out the plastic lining out of the jug when I first open it. The knife is super sharp, and the acid fumes haven't (yet?) damaged it. I don't think I can sharpen it, so I only use it for this purpose. By cleanly removing the plastic lining, I get no drips when I pour the acid into the pitcher.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Jun 2007
    New Jersey
    653
    I've been dosing with MA for 30 years. My pools were 40K and 30K, so I never measure. I just add 1/3 of a jug by eye when I'm low and retest the next day (or later the same day if I won't be around.) I keep a rusty utility knife in the locked chem/tool closet so I don't care if the acid ruins the blade--they're disposable. The key is to watch the wind. I split the jug between the two deep end returns, wind permitting. I work slow and careful and have never had a problem. I did have a jug leak in a car and I learned from that experience to transport the jug in a plastic bucket placed where it can't overturn and to make sure that cap is on tight. MA is not good for carpeting.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Mar 2009
    NJ
    215
    'Best way' is putting a whole bunch in a 15 gallon container and have it auto-fed when it needs it. Ha. Hey, I spent all that money on an swg sytem, so I'll brag about it! lol
    My buddy told me about the time he took an accidental whiff of the stuff and it almost knocked him out. Not that i didn't believe him, but when it happened to me, I immediately thought of him. That stuff is nasty. I started out wearing gloves, but doing it slowly, I've found that it doesn't splash, so I just open and pour..... into the 15 gallon jug, once a season.
    Come to the dark side...
    Maybe because I have an AGP and the water is very close to me. I don't have to bend down and pour even lower. That may make it easier to not splash perhaps. That 50% stregth option is a good idea, if it is truly half the price. I doubt that would be the case though.
    18' x 54" Round AG 7500 gallon w/small prefab 2-piece fandeck
    Waterways 200sf Cartridge Filter, 1.5 hp 2-speed pump. 2" pvc piping
    Pool Pilot Total Control swg w/acid tank feeder
    Pool Rover Jr., BBB, TF 100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I dip a 3 gallon bucket in the pool and fill it 3/4 with water. I eyeball the MA as I pour it in the water. I just put in a cup or so per bucket, let it set for a minute to let any fumes dissipate, and gently "sling" it into the pool. Repeat until I have as much MA as I need in the pool.
    I keep the MA jug in the bucket when store so I have a leak, it will be contained.
    I get a plastic knife at Wendy's to use to remove the seal on the MA jugs.
