Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: new pool - progress pics added.
    Mar 2010
    Western North Carolina
    77
    Hi, new here. We just signed our contract tonight so I'll be posting pictures when they get started in a few weeks. It's a pretty standard rectangle 16x34 vinyl. Were quite excited though.
    16'x34' IG Vinyl. 1.5HP Hayward 2spd. Hayward S244T sand. Nitro wall climber.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Re: new pool
    Congrats It will be very exciting and also very stressful but we at TFP are here to hold your hand all the way. Please post pics and specs and ask for suggestions
    Also read up on pool school and get a test kit. I like the TF-100
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Butterfly's Avatar
    South Carolina
    10,045
    Re: new pool
    Welcome to TFP
    We are looking forward to your build.
    You're done SLAMing when:
    Mar 2010
    77
    Re: new pool
    The first step is for us to put in a new septic system, and remove the old because it's in the way. That'l take a couple of weeks+ to allow time for the old system to dry out some before they dig into the drain field.
    The pool includes:
    28ml liner
    Hayward pump & filter
    color logic led light
    jetted steps
    2-wall jets
    1-skimmer
    mesh safety cover
    solar cover
    safety rope
    nitro pool cleaner
    poles, hoses, nets, etc
    first summers chemicals
    seeding grass back in
    130ft of black chain link fence
    25yds of extra concrete
    first opening and closing & training
    Mar 2010
    77
    Re: new pool
    New septic system is being installed today, and the old tank is being removed. They were working on it when I left this morning, so it should be done when I get home. I'll post pics if it looks in any way interesting.
    Mar 2010
    77
    Re: new pool
    The septic tank guy had a problem getting the bottom of the old tank out. He said it was 7ft below the surface, and seeing as it's at the shallow end it wouldnt be a problem to leave it in there. The inspector agreed that it was ok. Do you think it will lead to any issues to have a large piece of concrete a few feet under the bottom of the pool, or should I have them remove it when they dig?
    22,553
    Re: new pool
    It shouldn't be a problem. the biggest issue you have is making sure whoever fills the hole, fills it with structural compactable material and compacts it to 95% proctor density in no more than 12" lifts. If you don't know what that means don't worry just make sure they sign a paper saying that's what they're going to do.
    Mar 2010
    77
    Re: new pool
    Well, I figured I might as well post some pics before they start digging. This is the back yard after installation of the new septic tank. The pools going about where the trailer is, the far side being just past the walkthrough to the carport. The deck will extend all the way to the left side, so we can enter/exit through the french door also.
    I have to move the sat dish across to the back side of the car port. Gotta love cable and satellite instalers. We also have to move the power line and meter base around the corner. The power line is going to be buried.
    This is a bit further around to the right. The drain field installation made quite mess
    We've also had to cut down a large walnut tree. Don't want walnuts and the green powder from the leaves in the pool.
    Re: new pool
    Whereabouts in Western, NC and who is your pool builder? After a long delay due to the county and our septic system we are meeting with our PB to decide what shape and how we want the pool laid out. County had some interesting restrictions that really limited the size of our pool area. We are in Hickory and using EPI Pools.
    Lesson learned, get septic permit then design pool and get quotes in the future
    18' x 36' Vinyl Kidney 24,000 gallons
    Soon to have Salwater system up and running.
    Intelliflo pump, Colorlogic LED Light and a lot less money in the bank
    Mar 2010
    77
    Re: new pool
    we're in Burke county. Using Summertime Pools in Hildebran. I also spoke with Carolina Pool Builders. I know people that have used both and are very happy with their work. It's definately worth talking to more than one, and dont be afraid to ask for one to match anothers quote.
    The septic system takes up way more space than you think, then add in the future repair area, and you could be taking up most of your property. It seems that no matter the county, the admin folks aren't too helpfull. The inspector was the most helpfull person we dealt with.
    Re: new pool
    Yep Carolina quoted ours too. Very professional company but much more expensive then others around.
    We ended up with 6 quotes before we chose. Then had to change it all after our septicapades as we call it. Crazy you need room to rebuild your entire septic and tank, not just new lines.
    We decided today on a 18x36 vinyl kidney pool. Good luck with your build!
    Mar 2010
    77
    Re: new pool
    cool, make sure to post pictures of your build.
    Mar 2010
    77
    Re: new pool
    This is a very rough rendering of what were going to do. It is to scale though.
    Mar 2010
    77
    Re: new pool
    Just got a call from the PB. They're digging on Friday. Pool kit wont be delivered until next thursday though. Glad we're finally going to see progress. Will post pics.
    Rocklin, Ca
    467
    Re: new pool
    We need a 'LIKE' button like Facebook.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Re: new pool
    Looks great, lots of patio too. I am jealous and don't tell my wife but I would rather have a rectangle pool. Keep us updated!
    Mar 2010
    77
    Re: new pool
    Funny because I like the kidney shape, but the rectangle fits our yard better.
    Mar 2010
    77
    Re: new pool
    We have a hole. Now a week long wait for the kit.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: new pool - progress pics added.
    Let the fun begin!
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
  20. Back To Top    #20
    Any update? Did your pool kit finally arrive?
