Thread: Opening numbers are...
    Apr 2009
    Burlington, ON, Canada
    344
    I opened on Monday, and have only added chlorine to the pool. Water was mildly cloudy at first, but has nicely cleared up.
    Took a sample to the pool store today.
    Water temp 45 f
    2.65 total chlorine
    2.53 free chlorine
    Alkalinity - 60
    PH - 7.2
    Calcium 165
    Cyan - not done - was told the water was too cold for a reliable reading??
    Phosphate - 1000 (I know, don't worry about this one - but they did take a reading)
    Salt - 3200
    Now, they suggested I use the 'opening' kit, which contains 1kg oxidizer, 1 litre of stain and scale remover, 1 litre of 40% algicide. Is this really necessary?
    They also suggested I raise the alkalinity - how high should I go, considering I have a salt water pool? The chlorine generator is NOT on at this time (water too cold).
    Thanks.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    22,550
    Re: Opening numbers are...
    Quote Originally Posted by rcy
    Nice!! You were smart adding chlorine only. Not knowing what your CYA is but figuring it was at the recommended level for a SWG last year I'd raise your FC up to about 5 ppm to be safe until you can get it tested.
    Well, it is cold but all they had to do was let the water warm up and it would have been fine. This is one reason for owning your own test kit. You're not depending on someone else to do it and you know how accurate it is when you do it. Pool store numbers have proven to be wildly inaccurate.
    Not necessary or even wanted.
    The recommended goal is 60 to 80 so you're just at the lower end. I wouldn't recommend raising it yet.
