- Oct 18, 2009
- 3,638
- Plaster
- Hayward Aqua Rite (T-15)
Well I finally bit the bullet and had a solar system installed with some tax refund money :-D . Thanks to valuable info found here at TFP and advice from chemgeek, polyvue , no-mas , lborne, lee23903and mas985 and others as this is a valuable forum so I hope that my small contribution would be helpful to others. I decided to not peruse as a DIY as I know my limitations and I am not very good at plumbing
, nor do I have very extensive electrical knowledge
, and the thought of putting holes in my roof :grrrr: , to besides knowing my luck I would fall off the roof and break/ injure myself and would be out of work for several weeks,(Who would pay the bills then
), just did not make too much sense to me
. That is why we have professional solar installers and I hope that my small contribution will keep some people in business and food on the table for their families during these very challenging times
We had quotes from Fafco, Aquatherm, and Helicol and we chose to go with Aquatherm because we liked him, (somehow we just clicked) , he came out on a weekend, and he was the only Dealer/ Installer that would provide a written transferable lifetime warranty on top of the 20yr warranty for the panels and hardware and a transferable lifetime warranty against roof leaks/ repairs from the solar installation.
Please note that I was amazed at the level of professionalism displayed from his installers and the attention to detail. I will try to be as accurate as possible with the materials used and post before, during and after pics. I hope this is helpful to others and enjoy. I welcome all comments
Solar Description :
- 3- 4 x 12 ft Aquatherm panels ( 144 sq ft)
- 2 – 2 x 12 ft panels ( 48 sq ft)
- Total of 192 sq ft
- 20 yr warranty with 12 yr full replacement/ repair on panels and hardware
- Installer to cover transferrable lifetime warranty on panels and transferrable lifetime warranty on roof leaks
- Gl-235 Goldline controller, 3 yr warranty
- 2 – Jandy valves
- 1- One way valve
- Marine exhaust hose to connect panels
- Approx 180 ft of black 2 inch PVC
- Approx 20 ft of white 2 inch PVC
- Approx 24 -90deg black elbows, 10- 90 deg elbows
- 8 aluminum clamps holding headers, these are usually screwed into the rafters however my rafters were horizontal so they had to get into the attic and place backing 2 x 4 blocks for the bolts to screw into.
- approx 34 SS clamps for pipes,
- Coated SS flat strapping to hold panels
- Ability to withstand 150mph winds
- System wired to automatically turn on and off when it senses ability to heat, it must sense a 4 degree difference between air temp and pool water temp. Air temp sensor is mounted on the top header.
- Running psi went from 18 to 21/22 on the sand filter
- Pool temp increase from 61 to 69 running the solar for 3 hrs ( 4pm to 7pm) after install, outside temp high was 72deg, Sun not directly shining on panels.
- Roof orientation is 140 deg facing East South East, not the most optimum placement however this is the best place per the installer. Panels cannot be seen from the street, a good thing for aesthetics.
![hammer :hammer: :hammer:](/images/smilies/hammer.gif)
![Whoot :whoot: :whoot:](/images/smilies/woot2_106.gif)
![Party :party: :party:](/images/smilies/party.gif)
![Cheers :cheers: :cheers:](/images/smilies/cheers.gif)
Solar Description :
- 2 – Jandy valves
- 1- One way valve
![SIOCicW.jpg](http://i.imgur.com/SIOCicW.jpg)
![f7pG3xp.jpg](http://i.imgur.com/f7pG3xp.jpg)
![2dE35aM.jpg](http://i.imgur.com/2dE35aM.jpg)
![LFa8Drv.jpg](http://i.imgur.com/LFa8Drv.jpg)
![P64gN1Z.jpg](http://i.imgur.com/P64gN1Z.jpg)
![am4Im1R.jpg](http://i.imgur.com/am4Im1R.jpg)
![NBO0THf.jpg](http://i.imgur.com/NBO0THf.jpg)
![gAtSmuD.jpg](http://i.imgur.com/gAtSmuD.jpg)
![EVQGSPf.jpg](http://i.imgur.com/EVQGSPf.jpg)
